so are you guys making a 2bar OS for this?
'04 Tahoe AWD, trickperformance turbo kit, TC78 turbo, 4"magnaflow muffler, Circle D triple disc 3,000, FLT LVL 7 4L60E, L92, 227/235 111lsa.
Old 5.3=12.33 @110mph
http://www.streetfire.net/video/turb...mph_741849.htm
Awessome!!! Just suscribed... Thanks....
was that an 5.7 R/T or the 6 banger?
5.7 I believe, definitely not a v6.
sweet, plz keep me on the email for beta trials!
Bader Norris
MEP Tuned
Telephone: +965-55446651
Email: [email protected]
Point being we haven't even released basic operation to the public and already asking about custom operating systems...sorry to be the bearer of bad news(if you want to consider it that) but custom operating systems will likely not happen and at this point we haven't even looked into the possibility or necessity for them to be honest. Seeing it took us 2 or so years from initial release until we released custom operating systems for LS1 applications I would look at that timeline for a basic guideline for dodge & any other make/model for that matter and thats if its even possible.
So to answer your question no we have no short term plans for any custom operating systems and will play it by ear if they become necessity for some weird reason.
Sad that at the sounds of things that us JTEC people will probably be a year + down the road for a software release.
I have had my 392 SC small block ready to assemble for over a year waiting for your software. I am at a point that I must roll forward and finish my project using a FAST system as I have no interest in the other two software companies that is out there.
I do understand the time it takes to develop and test. I was there way back when we were trying to hack the GM code in the early EPROMs. I know its no comparison to todays PCMs but then it seemed like it.
Keep up the great work you are doing there are a lot of people counting on you.
Keith has an 06 Viper that runs the JTEC PCM, he is putting the pressure on me everyday![]()
I count sheep in hex...
I assume most would be unless in stock form it was boosted, then maybe they used a 2 or 3 bar sensor, you'd probably be best to ask around on the dodge forums regarding map sensors & such although we do have some Dodge guys here that MIGHT be able to answer that question, I'm just not one of them.
There are some people, and several supercharger companies who are tuning the NGC3/4 ecu's for turbo's and superchargers. It is a bit of a hack, because you have to disable the ecu's barometric compensation. That being said, it works well enough that, for the most part, most people would be hard pressed to notice driveability issues . So I believe, if you took the time to learn and understand how to properly calibrate these ecu's, you could tune a turbo setup to run ok with a unmodified operating system.
we'll see how things turn out, once we have the base product offerring in the market.
Can't wait for dodge support. Wouldnt beleive how many ppl ive had ask me about it in the past three days since i orderd HPT. i dont even have the software yet at all and already have four hemi trucks and a chrager R/T here local that want a basic tune. Never saw it coming. I'll be paying attention to this thread.
Will any of this include the dodge half ton hemi trucks?????
'97 Jeep Grand Cherokee ZJ, 5.2L (Canada Import), 2" Lift
(CAI, Modded Kegger, Ported TB, 3" Cat-Back, SCT Custom Tune)
'98 Jeep Grand Cherokee Limited ZG, 5.9 V8, Stock
'03 Skoda Fabia, 1.4L 16v
'98 Chevrolet Camaro V6, 3.8L, Targa, ZZP GT1 Cam, Dynomax Cat-Back [sold]
I must admit...I'm a little bummed. It's mostly due to ignorance on my own behalf.
You see, I was not aware that custom OS's were required for changing from 1 bar to 2 bar, 3 bar, or even 3.5/5 bar for that matter. I guess I just assumed that rescaling a PCM with HPTuners was as simple as changing the voltage vs psi scaling, and that it could be done within the software.
Then again, I have never used HPTuners before, although, I had VERY high hopes to be using this system in my SRT-4. Not trying to bash or make unfair/unreasonable comparisons, but DSP CMR software has the capability to re-scale for any MAP sensor or any size of injectors. So, I guess I was expecting that HPTuners would have this capability, as well.
What about the option to use a "Staged" PCM? Such as the Mopar S2/S3 PCM that is already calibrated for a 3 bar map sensor? Will these possibly be supported by HPTuners? Or is this something that has not yet been explored?
Any info is appreciated. And thanks for working on making this happen for us Chrysler guys.
- Chuck
'04 Dodge NSRT-4 - AEM EMS - AMS37R Turbo Kit
628 WHP 557 WTQ Uncorrected @ 4200 FT.
Stock Bottom End...
