Results 1 to 5 of 5
Thread: PLX as lambda in scanner
    Nov 2004
    231
    what would be the fomula to setup a plx sm-afr wideband to show units of lambda in the scanner (i dont think it matters but im using e10)
    wideband specs......
    Accuracy: < 0.1AFR (Gasoline) Wideband, < 0.2AFR (Gasoline) Narrowband
    Measurement Range: 10-20AFR, 0.68 lambda - 1.36 lambda
    Analog Outputs: Wideband Linear 0-5V, Narrowband 0-1V (Driving Current 20mA)
    Operating Voltage: 8V-18V
    Power Consumption: 30 Watts (Max), 18 Watts (Typical)
    Power Supply Technology: High Efficiency Switching
    Operating Temperature: 0 - 85 Deg C
    thanks
    04 VY Commodore ute M6 ls1, 918 valve springs, TR6 plugs, genttrbb twin turbo kit, 60lb seimiens injectors, Bosh 044 fuel pump, SX fuel reg, PLX wideband,Full Castle Hill Exhaust with 2 1/2in dump pipes, 4in cats into twin 3in cat back (no merge), Ripshift, oz700 clutch and 3.73 diff gears
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    (Voltage * 0.136) + 0.68
    or
    (Voltage / 7.353) + 0.68
    http://www.dsxtuning.com
    Just say no to bull s***.
    Nov 2004
    231
    thanks for that
    how did you come up with those numbers BTW
    Mar 2008
    St. Louis, MO
    4,863
    Basic math... or use Excel.
    0V = 0.68 lambda
    5V = 1.36 lambda
    The transfer function is ax + b, where b is your zero intercept and a is the slope of the transfer.
    b = lambda at 0V = 0.68
    a = (difference in lambda)/(difference in voltage) = (1.36 - 0.68)/(5 - 0) = .136
    To get it in the form HP Tuners uses, use the inverse of a, which is 7.353 (1/a).
    Nov 2004
    231
    thanks mate that explains it perfectly
