Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: LMM Dmax Tuning, anyone?
    Oct 2009
    Newbie to programming....
    Hi, I'm completely new to programming, but have over 20 year exp as a Diesel Mechanic and Marine Engineer.
    I've got a pet project I'm starting. That is putting a 2008 LMM duramax into a boat. I'm going to run with a full manual,2 speed power glide (without torque convertor) and a surface drive....
    455hp with this configuration should have me up around the 90Mph mark.
    I really want to get into the programming side, but The thing is I'm a bit in the dark as to where I should go with software.
    The 1st thing I want to do is do the softwear changes that will let me get rid of any unwanted codes due to not running the Allison and all the rest of the Controllers (TCM, BCM etc). I'll have a stand a lone harness.
    I don't want to go silly on bumping up the HP, 90+ over standard will be more than enough. (I'm happy to run with the 365hp for a start... but I would like to learn and play)
    There is a lot of info at EFIlive
    It looks pretty good here at HPT as well.
    I haven't purchased softwear yet (I'll be doing that in the next week or so)
    Guess I'm just looking for some positive feed back towards this product and tuning LMM 2008 dmax's
    Tuner in Training 03 D-max's Avatar
    Mar 2009
    42
    honestly if you dont have much tuning experience and are going to need help efilive is a better choice just because of the support. Duramaxdiesels.com would be a great place to join. lots of very knowledgeable duramax people there
    03 2500hd HPT, PPE, MBRP, K&N, SD
    www.DuramaxDiesels.com
    Advanced Tuner Programmer's Avatar
    Jul 2007
    244
    Don't worry--if you need help, just post something. Someone here will help.
    2009 Cadillac CTS-V 196.7 MPH on the Salt
    Superflow SF600 FlowBench -- Superflow Autodyn 30 Chassis Dyno -- Superflow SF901 Engine Dyno--RaceLogic Emulator -- MikiPro Logic Emulator -- ASNU Injector Flow Bench --
    Mar 2009
    42
    Quote Originally Posted by Programmer View Post
    there arent many people here that know anything about diesels but are more than willing to help with stuff they know nothing about. I tune with HPtuners but i knew what i was doing before i came to this site.
    Jul 2007
    244
    That's good...then hopefully as an expert you'll speak up.
  6. #26
    Mar 2009
    42
    I speak up as much as i can but the problem is people don't ask what tables do what, instead they ask for tunes and then when i publicly post tunes other people use them for there profit. I wouldn't call myself an expert by any means but i do have alot of dmax stuff figured out.
    To many people in the diesel section want to be spoon fed rather than figure out how to tune themselves.
  7. #27
    Mar 2021
    Anyone still have lmm tunes available?
  8. #28
    Mar 2021
    7
    Quote Originally Posted by tylerjofrankl View Post
    im also looking pm me thanks
  9. #29
    I've posted my 20/20 tune from my 2010 LMM in another thread you are welcome take a look at. Its for a lighter exhaust. Also there are some good ones in the repository.
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
  10. #30
    Mar 2021
    7
    lol lmao good ones in repository your funny , there all stock in repository hp tuners deleted everything . also i dl your tune already havent tryed it out yet tho . how much hp you make on it ??
  11. #31
    Sorry did not realize they deleted everything, must have been a recent event (wasn't meaning to jest as I used one from there). I have a couple decent ones that were available.
    My current truck tune i did not have dynoed or anyting like that. was just going for a good strong tow tune that didn't smoke. I get a touch of black at initial transient when you hammer it but overall seems to run swift, especially from the bottom (compared to before). its got more to go but i am being gentle on the tranny. Just data log and you'll find spots to tweak. Watch your EGT's when you start adding fuel. The more fuel you run, the more air you need keep down the temps. Of course timing plays into that as well.
    There was one in the repository that ran great but, you'd want to have a strong tranny thats for sure.
  12. #32
    Feb 2024
    I will ask. What tables do what? I am a mechanic and have done a very small amount of tuning on gas vehicles. I am lost with diesel. My brain has a hard time with not having a throttle to control air onto the engine.
  13. #33
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    479
    Quote Originally Posted by Pumpkin View Post
    That?s a super vague question man. Not being an asshole but there are ALOT of tables. It would be a book if someone wrote out what every table means/does.
    In vcm editor there is a description if you hover over the map. The description is down at the bottom of the window.
    If you need further help you can PM me
  14. #34
    Feb 2024
    Is it possible to copy a tune from anther truck and load it to my truck? I downloaded my sons tune that is also an lmm. can i just load that to my truck. Excuse my terminology, I hope you understand what I am trying to ask.
  15. #35
    Its frowned upon and could brick an ECM but....I've done it. Also would need to license your truck AND the tune when you load it (double hit). The appropriate way is to compare to the modded tune, and make the changes. Then you simply license your tune/truck once and know the segments are exact.
  16. #36
    Dec 2023
    Quote Originally Posted by kindaslo View Post
    I have some lmm tunes..
    stock,60/90/120/220 hp...
    If you areinterested shoot me an emial.
  17. #37
    Dec 2023
    IM IN NEED OF
    If you areinterested shoot me an emial.[/QUOTE]
  18. #38
    Jun 2024
    Hey im looking for a tune file, i just finished a delete on my 20 L5P and the seller did not send me a EGR unlock file. I need help
  19. #39
    SoCal
    1,631
    Quote Originally Posted by beastandbeauty View Post
    Likely that they didn't want to get caught in the "new" EPA/ARB rush to prosecute deletes.
  20. #40
    Jun 2021
    5
    if you could email me at [email protected]
