Results 21 to 40 of 48
Thread: Has anyone used an 07 ECU in an 06 Z06
    Quote Originally Posted by Nick@Newtech View Post
    Read my post ^^^ I see that the oil pressure will have problems due to the pinouts, its not the motor most likely.
    Thanks I will pass along the info. Not sure how it would be effected as I used an 07 file in his original 06 ecu though. (didn't install an 07 ecu)
    He did call back and said his oil pressure was now 35+ at idle and everything "seemed" fine. If oil pressure was messed up due to a different year OS I'm suprised the gauge would work at all.
    The car will be dropped off next week so I'll let you know what I find.
    07 ZO6- warhawk 427/APS TT/HPT 2.5bar
    [email protected]
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    If somebody finds a way to make an 09 LS3 PCM work in a 2006 Z06... I'm all for it.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Feb 2006
    245
    my buddie......real smart cat, told me that it would be almost impossible cause of "placement" of the vin in the pcm. what that means i am not sure but....
    Jun 2005
    Southern FL
    2,044
    It shouldn't matter where the VIN is, as HPT would recognize it as an '09. What matters is that the wiring schematics are proper, and that the TB and ETC system recognize it properly.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    By the time we get all the harnesses made, im sure HPT will have a 06 OS ready by then......... lol
  6. #26
    Mar 2008
    St. Louis, MO
    4,863
    Yea, but it won't have the double injector limit.
  7. #27
    With SD who cares, bring me the 06 custom OS !!!!!!!
    [email protected]
  8. #28
    Jun 2005
    Southern FL
    2,044
    What do you mean who cares? SD still needs proper injector values just as MAF does.
  9. #29
    Quote Originally Posted by RWTD View Post
    It doesn't "need" proper IFR. I have 100lb/hr injectors in my car and it's tuned perfectly.
    Double injector limit would be nice but it doesn't pose an issue for me.
    Same thing with the C5's when you have to scale down ifr and ve to keep from hitting g/sec limit. The IFR is no longer "correct" but it doesn't stop the car from being tuned and running 100% perfect.
    [email protected]
  10. #30
    Oct 2007
    346
    whatever changes you do to the IFR tables will DIRECTLY be reflected in the VE tables, as in:
    - do whatever changes you want by scaling the IFR table, upload the tune. Now download the tune, look at the IFR table and it will be composed of ONE number (eg. 7.3) for the entire range, but you're VE table will now look way different as all the changes made were automatically incorporated into that table.
    I dont know if this is common knowledge, but this is what I found out a few days ago, and called it the 2.5bar magic ve tuning trick.
    NOTE: which I think proves INTMD8's point that IFR table is useless in 2.5bar, RWTD maybe you should try it and see.
  11. #31
    Not sure what's going on there ^^^ as the IFR and VE has always remained with the values I enter. (my IFR is entered as 62.04) which, also happens to extend the usable range of the spark timing tables (as in it's not running in the bottom row at base boost, there's enough range to decrease timing along with higher boost levels).
    I'm not saying it's "useless" but it can certainly be worked around.
    [email protected]
  12. #32
    Oct 2007
    346
    Quote Originally Posted by INTMD8 View Post
    OK, i dont know if I missed something there, but let me tell you what happened the last few days.
    We were tuning the car by scaling the IFR vs pressure delta table, we did not even touch the VE table, until the car was running at around 11.5x under boost and left it that way.
    Anyways, We got the original copy which we worked on, which has the IFR table scaled, and I got to read the SAME file from the ECM and they were different. The one we read from the ECU had one constant number for the whole table, but had all the changes automagically in the VE. If this sounds weird, I can post both files on Sunday.
  13. #33
    I think you may have been confused with what files you were using. For one you should be tuning the car with the VE table, not the IFR table.
    Secondly, by making changes to the IFR table, it's not just going to re-set and automatically make changes to the VE table.
    [email protected]
  14. #34
    Oct 2007
    346
    Jim, trust me im just as confused as you are lol, but it did happen, and im not confusing between different files at all.
    We were scaling, saving, dumping the file into the ecu, til we got a steady AFR. Later when we read the tune, IFR was at 7.3 throughout the range, with all changes onto the VE.
    Again this sounds crazy, and yes we were not supposed to tune it like that, but this is what happened, does this 2.5bar OS have something that we dont know about?
    FYI, to duplicate what I saw, youd have to have a scaled table (not constant), upload, probably start the car, read the file and compare with the one you uploaded.
    not a tuner here, not even close YET but trust me on this one lol, maybe someone from HPT would like to comment on this.
  15. #35
    Mar 2008
    St. Louis, MO
    4,863
    I don't think anybody's doubting the ability to tune a car correctly by scaling... The point is that the 09 LS3 PCM doesn't have to be scaled, so you still retain resolution and it's just one less big step you have to do.
  16. #36
    Quote Originally Posted by ayousef View Post
    I don't know what could be going on there but if your IFR is 7.3 I would say that is a problem. I have flashed 2.5 OS cars and re-read the file and they were exactly the same.
    [email protected]
  17. #37
    Yes I realize that thanks. To clarify, basically my post was joking around, saying I'd be happy to get the custom OS even without a doubled IFR table hence the ->
    [email protected]
  18. #38
    Oct 2007
    346
    Jim, sorry to confuse you, thats in g/sec [metric default] unit.
  19. #39
    Ok, that makes more sense. I still believe there should be no way possible that changes to the IFR table should in any way be able to change the VE table.
    [email protected]
  20. #40
    Oct 2007
    346
    Jim, I asked someone from HPT to comment on this, let's get a definite answer, and ill actually try it again just to prove myself right , or wrong for that matter
