Page 10 of 13 FirstFirst ... 678910111213 LastLast
Results 181 to 200 of 249
Thread: 2.5bar for E38 ECM's features and devtest results
  1. #181
    Oct 2008
    297
    also would be nice if the 2010 camaro gauge pack would work after flashing with hpt
    2010 camaro L99, Magnacharger TVS 2300, 415ci LS3,Kooks long tubes, yank ss3200, 3.73 rear
  2. #182
    Quote Originally Posted by camaro1 View Post
    is OS 12635863 in the works?
    yes it will be in next beta also & 12633056
    I count sheep in hex...
  3. #183
    Oct 2008
    297
    if you upgrade to the 2.5bar OS can you still keep the maf, and take advantage of full cooling fan control?
  4. #184
    yes, but you need to populate the VE tables.
  5. #185
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    Is there a simple option to turn the MAF off with the custom OS? I've never played with any of the custom ones.
    http://www.dsxtuning.com
    Just say no to bull s***.
  6. #186
    unplug it and get an IAT sensor kit if the IAT is part of the MAF. Or leave it plugged in and set the MAF fail freq to 0.
  7. #187
    Mar 2008
    St. Louis, MO
    4,863
    Quote Originally Posted by Chris@HPTuners View Post
    With the custom OS, will this make the low octane timing map the default one? I plan to retain my MAF, but I'm more just curious for when I'm dialing in the SD table.
  8. #188
    newer code doesn't default to the low octane table, only LS1 does this.
  9. #189
    Mar 2008
    St. Louis, MO
    4,863
    I'm doing the happy dance, because I just got an email stating that it's available for 2006 Z06s.
  10. #190
    Oct 2008
    297
    is the new beta out?
  11. #191
    28,312
    Yes
  12. #192
    Is it a 2bar or 2.5bar for the 06?
  13. #193
    28,312
    2.5 bar, but you can use anything from 1-2.5 bar in reality since the axes are adjustable.
  14. #194
    Oct 2008
    297
    anyone put together a starter VE table yet? do you need to change the axes if you are using a stock map sensor,, or do you need to change to a min 1 bar sensor to use the ve table?
  15. #195
    the 2bar automatically changes the map sensor calibration to somthing suitable for common 2bar sensors. If you are using a 1bar sensor (the stoick one) you need to change the MAP Linear and MAP Offset back to the stock values.
  16. #196
    Mar 2008
    St. Louis, MO
    4,863
    You can use the EQ_VE program to generate a copy of the VE table, but you need to edit the table dimensions file and add a new table with the same dimensions as your custom VE table. The problem I ran into when doing this was when the prorgam generated a table, all of the columns were out of order. I just had to copy/paste columns individually and put them in the right spot in my tun efile, and it all worked out.
    Now I just need to figure out why the custom OS is putting my car into closed loop almost right away, even with cold coolant.
  17. #197
    28,312
    From my understanding many are using the stock VE table from say a 2005-2006 GTO or 05 vette...its a little bit of work involved in interpolating between bounds but that shouldn't take more than 5 or so minutes then just save it as a txt file in our software and you'll always have a starter ve on hand
  18. #198
    Feb 2006
    245
    chris what are ur thoughts on leaving the maf active but fail at freq. were boost kicks in? might make for a nicer overal tune. would there be issues (stumble ect..) in transitions?
  19. #199
    28,312
    Quote Originally Posted by NICKY BOY View Post
    I know if you set it like this on gen 3 pcm's when it fails it fails & doesn't "unfail" until you turn off the vehicle...I assume E38's are the same.
  20. #200
    Feb 2006
    245
    ok.....
    bill u got email
