Results 1 to 20 of 28
Thread: wideband question
    Advanced Tuner printmanjackson's Avatar
    Nov 2009
    USA
    412
    wideband question
    ok, I'm new! Let's get this out of the way just in case you can't tell
    My question is why do I read where people permanently install a wideband? Is this something that has to be monitored? This is the case with the Innovate LC-1 Wideband and from what I understand is one of the best to use. Can you not do tuning without having to permanently mount a wideband? What's the advantage?
    Nov 2009
    USA
    412
    second question, how many credits with my LS1 C5 MN6 Vete take to tune?
    28,313
    2 credits for single vcm license 6 for year/model.
    Nov 2009
    USA
    412
    what about my first question? Please
    28,313
    Dunno, I made mine removable.
    Nov 2009
    USA
    412
    please do tell
    Dec 2008
    Old Orchard Beach Maine
    915
    let me try to answer your wideband question with some detail
    first off its all personal preference
    some will replace a factory 02 sensor with the wideband while tuning and then remove for daily use
    others will weld a bung in place on their exhaust that they can permanently install a wideband - or they can remove it when not tuning and thread a plug into the same bung
    yet others will install a wideband in place of a stock 02 sensor and wire it in in a manner that it replaces the narrowband permanently so any pcm adjustments based on 02 sensor data are based on wide rather than narrow band , problem with that is narrowbands are more accurate during normal non WOT operation - I want to say its called narrowband simulation
    the longer the sensor is installed in the exhaust the sooner it will wear out
    PB's 1/4 mi 12.21 117.75 trap ,1/8 mi. 7.779 93.99trap , 1.949 short time (FWD W body)
    I have a aem that I run all the time, then I also have a lc1 that can be moved from car to car.
    04 M6 GTO
    Mods: HP Tuners
    11.8 @ 123
    11.0 @ 135
    Tuner jacagle's Avatar
    Nov 2008
    Newton, Ks
    103
    i just had a bung welded into my car for a permanant WB install. i figure for 175 bucks its the best way to go. the portable ones are about double that from what ive seen, so might as well get two lc1's
    2000 Camaro Z28- stock motor. P/S LT's, TSP TD bullet style mufflers,de screen maf, LID and K&N filter. 2.73's
    180,000 miles and going strong!!
    2004 Silverado 2500HD- stock 6.0, drop in K&N filter, 285-75/16 sport king A/T's.
    Nov 2009
    USA
    412
    Thanks for the info, very good explanation!
    I have heard if you leave these installed without them power that it will burn them up. Is this just BS of truth?
    Does it matter that WB you use or is there certain ones that will work with HPT?
    Feb 2009
    11
    not powering the sensor will burn it out in no time. I had a used LC1 and could not get it to work so bought a AFX and couldn't be happier. Again LC1 was used.
    Nov 2009
    USA
    412
    does that mean if you get one with a guage then it should last longer? seems easier than plugging and un-plugging it in.
    Nov 2009
    USA
    412
    will the HPT work with any of the Innovate widebands? Does one of different models work better than the other? There is the LM-1, LM-2, LC-1 models
    Nov 2009
    USA
    412
    another WB question. Can you use the data collected with the Innovate LM-1 recorder box and download it to the HPT?
    Feb 2006
    Canada
    1,963
    1)WB is a heated sensor and with mine there is a 20 second warm up before I can start the car. Not allowing the sensor to heat up will kill it fast as said above. Don't ever have it in the system without power, just not good.
    2) *recorder box* Dont think so. If you have the Pro, just send the analog out to the Pro. The recorder box could be referenced for quick checks to see if you need to pull out the Big Guns, aka, your HP Program!
    3) I have to add, go for the NTK/AFX set up if you haven't already bought one. The sensor that comes with it is a good, quality sensor but you can order it with the "upgraded" sensor if your so inclined for a extra few bucks.
    Nov 2009
    USA
    412
    Quote Originally Posted by MMGT1 View Post
    what does the upgraded sensor do?
    Feb 2006
    Canada
    1,963
    Last longer and short of spending 5K on a Lab Grade one, it's the most accurate combo you'll find.
    Here is the "Standard":
    http://www.bmotorsports.com/shop/pro...roducts_id/357
    Here is the "upgrade":
    http://www.bmotorsports.com/shop/pro...roducts_id/582
    Something I just noticed... if you buy the upgraded kit, it comes with both sensors! The one in the kit is the standard, and the upgraded one is added. You will have a back up when your main sensor goes down and needs replacing eventually. Any down time can be covered with the standard sensor.
    Tuner BlackZJ's Avatar
    Apr 2008
    German speaking part of Switzerland
    159
    What about the Dynojet Wide Band 2? Is this a good device?
    '97 Jeep Grand Cherokee ZJ, 5.2L (Canada Import), 2" Lift
    (CAI, Modded Kegger, Ported TB, 3" Cat-Back, SCT Custom Tune)
    '98 Jeep Grand Cherokee Limited ZG, 5.9 V8, Stock
    '03 Skoda Fabia, 1.4L 16v
    '98 Chevrolet Camaro V6, 3.8L, Targa, ZZP GT1 Cam, Dynomax Cat-Back [sold]
    Nov 2009
    USA
    412
    ok, what about the sensor location? where do I mount the bung? I'm running LT headers. I'm not running cats so can it be anywhere after the collector?
    Nov 2008
    Newton, Ks
    103
    I Put Mine Directly Under The Driver Seat And Ran The Wires Up Throught The Drain Plug In The Floor Board. Made Me Feel Better Having The Controller Inside The Cabin Away From The Harsh Under Carridge.
