Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: has anyone logged 6l80e pressures
    oh no
    bump.... is this beta ready?
    28,312
    Quote Originally Posted by icicleboy View Post
    No.
    No.
    eta?
    28,312
    Likely a few days but could be longer, we'd rather do it right than just slap something together so that it gets out quicker.
  6. #26
    28,312
    New beta up for those that requested it thus far.
  7. #27
    Oct 2008
    297
    thanks,
    i just changed the SHIFT PRESSURE DEFAULT to 147, and the new table MAX PRESSURE to 150
    then did a couple wot shifts and noticed no change at all in shift feel, and in the scan tool the pressures still max out at 109.9??
    2010 camaro L99, Magnacharger TVS 2300, 415ci LS3,Kooks long tubes, yank ss3200, 3.73 rear
  8. #28
    May 2007
    Hammond La
    28
    update
    Bill Can you set me up with the update.
    23 Year GM master tech, Corvette specialist, Owner Blanchard Performance Engineering
  9. #29
    Tuner Dan Wendling's Avatar
    Apr 2009
    Gaithersburg, MD
    71
    What is the status?
    What is the status of this fix. I have seen a couple of posts that claim the Beta did not fix the pressure settings?
    I have Beta 2.23.3567.30387 that I understand included the initial fix. Is there a new Beta that updates the fix?
    2009 Cyber Gray C6 Coupe, A6, F55 Shocks, Z51 Brakes
    Halltech Killer Bee, Comp Springs, Kooks 1.75 Long Tube Headers, Random Technologies Cats, .25" Tunnel Plate, RPM 3.42 Rear, 2600 Stall TC.
  10. #30
    Apr 2009
    Gaithersburg, MD
    71
    Any updates on the status of this fix?
    Bump
  11. #31
    Advanced Tuner midevil1's Avatar
    Feb 2009
    TX
    365
    Any luck with a fix? 2-3 shuttle shifting is becoming a problem with this box when aggressively tuned without the added pressure. Diffenately limiting the ability to tune correctly.
    2023 Ford Edge ST
    2020 Ford F150 King Ranch 5.0
  12. #32
    Oct 2008
    297
    line pressure is still limited,, my car is now put away for winter, almost wondering if these handheld tuners have any better luck raising pressure, several of them say that they can raise the line pressure on the camaro 6l80e
  13. #33
    try setting the max clutch pressure and others to something like 400 psi (ie. double what you want).
    PCS1 is the main line pressure that feeds the individual clutch solenoids, it is controlled by the base shift pressure tables. Again these values might be calibrated to double what they show in the scanner. The clutch solenoids are downstream from the main pressure reg so even if the command a higher number they don't actually get the pressure unless the base line pressure is increased.
    In many cases these maximums are calibrated after the pressure regular gain (approx 2.0) so pressures in the cal are double what you see in the scanner.
    I count sheep in hex...
  14. #34
    Jan 2006
    Collinsville IL
    697
    Quote Originally Posted by Chris@HPTuners View Post
    funny u say that i pulled a Superchips CORTEX tune(awhile back months ago)
    the table that is 275.6 from the factory(maximum line pressure) is 400 PSI...
    https://www.facebook.com/tuningbyshanehinds
    [email protected]
    2009 G8 GT [email protected] 1.60 - Sold
    2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
    2013 CTSV wagon 9.21@151
    2015 C7Z bolt ons 10.0
  15. #35
    Jan 2006
    Collinsville IL
    697
    btw so ur telling me the max line pressure vs gear Vs RPM changing that does nothing?
    [email protected]
  16. #36
    Jun 2009
    202
    Any updates?
  17. #37
    Oct 2018
    49
    Yeah, not looking to ressurrect this from the dead, but I am also not looking to make new threads when this has covered alot. Will this ever get "Fixed"? I'm trying to tackle some flaring issues and I don't know what numbers are real, and what isn't. Kind of defeating the purpose of taking logs, if the logs aren't helpful. To be fair, this 6l90 has been a nightmare to get dialed in. Some people make it seem so easy but for me, its either shifting like a lightswitch on the 2-3, like .08s no matter the engine load, or If I load the factory tune, flaring on the 2-3 and 3-4. Fast adapts have been performed. I can definitely figure it out and get it tuned nicely but I am just trying to gauge what the pressure readings really mean.
