Results 1 to 7 of 7
Thread: why are my afr's all over
    Tuner cfar's Avatar
    Mar 2007
    FL
    107
    the truck runs well-but on hard accel afr drops to 10 and losses power because its to fat-some time will also go to 10afr on 3/4 throttle.Have tried to delay PE but still happens-any suggestions?
    some specs...running 2 bar SD os
    5.3 bore to 5.7-h beam rods-forged blower pistons 8.5 to 1 compression- whipple at 10psi-55 lb inj-comp blower cam-headers-built 4l60 and 4.10 gears
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    any details about the truck. Fuel system, mods, etc.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    28,303
    scanner log may help
    28,303
    dtc's should be set to no mil light, not mil on 2nd error.
    Tuner cfar's Avatar
    Mar 2007
    FL
    107
    sorry just changed thet in a effort-will revert back to no mil you mean po101-102-103 ?Thanks
    Tuner cfar's Avatar
    Mar 2007
    FL
    107
    Quote Originally Posted by 69lt1bird View Post
    forgot has walbro 155 pump
    Tuner cfar's Avatar
    Mar 2007
    FL
    107
    i do one and post it -thanks
