I wanted to see difference between OL and CL MAF afr error% with VE table completely disabled. OLFA table is also all 1's at operating temps for this test as well.
After a long drive not going into PE in OL I have maf afr error to within 0-1% all the way across all cells. I then went to CL and went on same drive, same conditions and maf afr error was now +4-6 % yet stft's are showing -1 to -3's everywhere in histogram and 0-1% in MAF stft error %.
If my VE table is disabled what is causing the difference in afr error % between OL and CL? Are the narrow bands in CL not accurate with my stoich set to 14.27 for the 7% ethanol in my fuel so in OL its more accurate? And if so how to correct for this while in CL?
I run pure maf CL with no VE table referenced so just trying to figure out whats causing the difference and which is more correct for MAF error % the stft's in CL or the WB error % when in OL.
