Results 1 to 17 of 17
Thread: VIN/OS mismatch
    May 2010
    32
    VIN/OS mismatch
    Just bought hptuners. When I read the PCM, and try to license it, it gives me an error VIN OS mismatch. The car is a 2000 fbody, with a 2002 OS installed. How do I get the licensing to work?
    28,319
    By having the pcm flashed with a valid vin/os pair & then reread with our software.
    May 2010
    Cumming, GA
    6
    Im having the same problem. Since I bought this software to do just that, are we now in a catch 22?
    Software was bought to flash firmware. But I cant read, change VIN, and write with a correct VIN/OS pair?
    What is the work around?
    Mike
    Cumming, GA
    1999 Miata BF LS6, 6spd, 3.23 rear. Still getting bugs out.
    http://www.mstewart.net/miata
    28,319
    Quote Originally Posted by rvsuper8 View Post
    Mike
    Your pcm currently has a mazda miata vin number so our software doesn't know how to license it as mazda miata's are not a supported vehicle. PCM swap or not the vin is not supported.
    May 2010
    Cumming, GA
    6
    So here is what I want to do.
    I want to read the PCM currently running, change the vin to a supported one (I have the GM VIN), and flash to use.
    What is the process. Ive tried to work this in the software and I cant seem.
    Are you saying I have to send my PCM to another programmer with a better software package that does not have this restriction so they can put a supported VIN on my PCM?
    Cumming, GA
    28,319
    Tech 2 from any gm dealership can flash in a valid file with a valid vin.
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Bill,
    Why don't you just tell him to read the file off the PCM, drop in a valid VIN and then re-flash the PCM?
    Steve Williams
    TunedbyFrost.com
    28,319
    Quote Originally Posted by Frost View Post
    Bill,
    I'm not sure that he can because the vin in the pcm is screwy, pretty sure the software will see that and reject it.
    Tech 2 to stock vin/os I KNOW will work.
    Jan 2006
    Richmond VA
    1,950
    I've never had a problem reading any file. Once it's read, you update the VIN and you are good to go and get to keep your calibration intact. The TechII is going to wipe it out.
    Steve Williams
    TunedbyFrost.com
    Tuner macca_779's Avatar
    Sep 2009
    Katherine N.T Australia
    70
    Then he would loose his custom tune.
    Do what Frost has said.
    If he can't read the controller at all. Then the only alternative I can think of is to get it read by the other LS1 based software that doesn't care about VIN's and change the VIN with that so he can use it with HPTuners.
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Any reason you can't change the VIN with the "VIN changer" part of HPT? Not sure if you need to read it first though.
    Always Support Our Troops!
    28,319
    Quote Originally Posted by EC_Tune View Post
    He would need to have the license for the vin currently in the vehicle as well as the vin he's trying to change it to.
    not sure if i'm having the same issues, but i've got two cars here now giving me invalid vin/os error. i'd love to just change the vin, but as soon as it's done reading and the error comes up-flashing is disabled........
    Jan 2006
    Richmond VA
    1,950
    Save the [Read] file. Open the file, update the VIN and then save it with the new VIN. Now flash it.
    Steve Williams
    TunedbyFrost.com
    28,319
    Quote Originally Posted by tommytuner View Post
    The error states exactly what steps you need to take.
    Oct 2010
    Im having the same problem. Any one know exactly what to do? I was thinking of finding a stock .bin file and downloading it on my computer and licenseing it that way then just try and load that stock file on to the pcm. That should work right?
    28,319
    Quote Originally Posted by kasey View Post
    What does the error say to do?
