im having a problem with idling. its an 02 l61 with stage 1 comp cams and high flow intake, and the cat has been removed along with the resonator right behind it. i just put a new map sensor in it and it made a huge difference. so its a known fact that the old one was causing a problem. im still having a problem at idle. when it sits at idle for a bit the stft leans out and the engine begins to surge and show spikes in the spark advance graph. theres a log that shows it below. frames 450-600 are a perfect example. ull notice that the iat is ~120 deg but it also does it with the engine cold when temps under the hood are cool. the reason for the high temps are that the cone filter is sitting right by the engine. ive also uploaded the tune i used. its my 42nd and has provided the best results out of all of them. ive tried making changes with the ve and the spark advance and nothing. wat do you suggest i change?... thanks in advance.
