Hello All,
Working on a 2009 Caddy CTS-V with full exhaust, Hennessy Cold Air Intake and Lower pully upgrade to make 15-16 psi. Has the Siemen/Deka 60lb. Injector (shorties), p/n 107962. Tried rescaling IFR with info posted on here and couldn't get fuel trims to lean out. Was pulling up to 25% fuel out. Ended up rescaling the MAF to get it in range. Fuel trims at idle are good now, but go a little crazy at part throttle. I know on some of these cars the IFR, MAF and VE need to be rescaled due to the 63 limit in the IFR, but the IFR table in the CTS-V can go much higher. Doesn't seem to make much of a difference though. I will post up scans and tune when I get back to office. Any thoughts on why it's still so rich with injectors rescaled?
