I recently bought a wideband and I am planning on hooking it up through the egr this upcoming weekend. I read somewhere that there should be a table that adjusts the timing based on EGR pintle position but I don't see this on my 97 camaro v6. I have already removed egr so I will have to enable the dtc for pintle position. Is this the only egr related dtc that will have to be enabled? Also, if I run the wideband through the EGR will the timing be affected since I don't have this table? Thanks.
