Results 1 to 7 of 7
Thread: Weird runtime error with decimal values
    Potential Tuner bluethunder2000's Avatar
    Mar 2009
    France
    6
    I'm using the VCM editor release 2.22.
    I was working the primary VE table and needed to myltiply some cells with a given number, and whenever I entered a decimal number, I got a runtime exception complaining that the input string is not a number in the proper format.
    Example: entering 2 as multiplier was OK, entering 2.1 resulted in the exception.
    The details indicated that some runtime library could not resolve the input string, and convert it to a double format. I tried other things like putting a comma or other illegal characters in the input and the software remained robust, ignoring this input and not raising any exception. This happens only when using a number with the decimal point in it.
    This problem seems to occur for all tables where I tried to enter a decimal number as add or multiply operator.
    I'm stumped. I got a workaround, I work the tables back and forth with Excel, this allows me to tune the car by pasting the updated tables in VCM editor.
    I realised that my PC was running the .NET framework 3.0 so I uninstalled that and reverted to 2.0, no change. The PC runs XP Home service pack 2.
    I have a hunch that this has to do with local language settings. My PC is setup with a french version of XP, which expects the decimal numbers to be identified with a comma (example: 2,2 is the way to write 2.2 in french). My Excel license works that way. I suspect that HPT discards the comma and only accepts the decimal point, and when entering a number with a decimal point in my Excel I get very large numbers, so the routines will provide incorrect output with decimal point.
    Any ideas ?
    Patrick
    28,303
    Contact support, I'll have you test 2.23 to see if its fixed.
    Mar 2009
    France
    6
    OK
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Go to Control Panel and check you regional settings.
    I once had a very similar problem and it was because the number format was 2,1 instead of 2.1 (the decimal separator was a comma, not a dot)
    I changed the settings and everything back to normal.
    2.23 Beta fixed all my language settings(swedish with ",") problems.
    C5-2000 MN6 LS2 block Tony Mamo FAST90+Ported LS2 TB 100mm MAF AFR 205 59cc CompCam 921 Yalla Terra G5X1 LG Pro Headers LG G2+T1 Chassie LG ducts MOVIT brakes - HPT&NGK AFX
    //Sweden
    Mar 2009
    France
    6
    Thanks guys - thats what I thought.
    Damn comma getting in the way.
    Apr 2010
    Estonia
    16
    I had same problems for months, thank god I found this topic right now...
    Language : Estonian
    we use also comma
