I installed a TransGo shift kit and the 1-2 shift is really firm. What can I do to lower the firmness on just this shift?
Thank you
Thank you
Thread would probably be answered sooner in the Transmission Tuning forum.
How many washers (if any) were installed when the shift kit was done? Was the separator plate drilled out the most you can? When I had mine setup for full race it was possible to get low throttle shifts to be smoothed out a bit but wide open was always a bang and scratch of the tires.
'20 AT4
'01 Suburban 2500 Dad Wagon
post your current tune, maybe the pressure was modified before the shift kit and this would also cause harder shifts.
The best "correct" way to fix it is to remove a washer from the 1-2 accumulator. Most people think that the 1-2 shift is too harsh with just 1 or no washers in it. I ran mine at full race because I knew that every time it shifted into second it wasn't going to slip no matter what. Never had a problem even with a tight converter. Only thing that sucks is when you drive someone (women especially) around in your vehicle that has no idea what a built trans is it's hard to explain how the hard shift is good lol
'20 AT4
I would agree if the shift pressure is stock. I also agree to warn passengers (signed wavier) of the possiblity of neck breakage when the trans shifts.
I have the 3 shims and race holes drilled but I adjusted pressure to make it hook when hitting second and third gears. Shift times also help a bit.
Yes, if you have ever had the PCM tuned check the shift pressures to make sure they are stock. Pressures upped in the tune and the trans make it too harsh.
Post your stock & modified tunes, and I'll fix your harsh 1-2 shift. Had a customer with a 4L65E trans that also had the Trans Go stage I (HD) shift kit installed. Even the light throttle 1-2 was too harsh. Adjusted the 1-2 shift pressure in normal & tow haul, no more harsh 1-2 shifts.
Russ Kemp
