Results 1 to 18 of 18
Thread: Tuning help for 09 Silverado with Cam
    Nov 2007
    Huntsville, AL
    29
    I need some help please. I have a 09 Silverado with the 5.3. I just recently installed a Comp Cam 54-418-11 224/228 0.534 int./0.537 exh cam. The problem that I am having is, I keep getting the check engine light on complaining about the motor running lean after the cam install. I have called comp cams about the problem and all they will tell me is that I have a tuning problem. I then called Summit Racing about buying new 36# injectors for the truck since the truck only has stock 20# injectors installed. Their tech support told me that I don't need bigger injectors but per their Comp Cams notes, I have the wrong intake on the motor. Summit said that I needed the 6.0 litter intake or a FAST intake, not bigger injectors per Comp Cams. I currently have the stock 5.3 intake on the motor. I have logged the injector percentage duty rate. The most that I’ve seen the duty rate was at 81%. I am also using the HP Tuners Beta software. I don’t know what to do. I can’t get the same answer from the two companies.
    28,319
    What dtc's are you getting?
    28,319
    According to the ifr table it looks like those are actually 36# injectors, not 20lb.
    Nov 2007
    Huntsville, AL
    29
    DTC is Bank 1 &2 Lean
    How can you tell that they are 36# injectors. I'm still learning.
    Jul 2009
    Noble, OK
    317
    If you are lean, the intake isn't the problem.
    Nov 2007
    Huntsville, AL
    29
    Thats what I told the Tech support at summit. How was adding more air into the engine going to correct the lean fuel condition? He finaly agreed with me.
    28,319
    The Injector flow rate table tells you what the injectors were originally setup as.
    What DTC code? P0171? etc. In my experience p0171/172 type codes are caused by maf issues so thats the first place I look.
    Nov 2007
    Huntsville, AL
    29
    Bill, I am getting P1174 followed by P0300.
    28,319
    I've honestly never seen that code throw before(p1174) maybe someone other than myself has experience with it.
    P0300 is a general misfire code that usually pops up when an aftermarket camshaft is installed, thats pretty normal.
    Nov 2007
    Huntsville, AL
    29
    Ya, from a little need web search. From what I have found from a colbolt site is that I may have one or more injectors clugged. I just wonder if the warranty will cover that after the cam I installed.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,215
    Not sure how your getting a lean code when the fuel trims are negative. Should have a rich code, not a lean code.
    Russ Kemp
    28,319
    Russ from what I can tell the problem is the o2 sensors are just dead for portions of the scan, for instance frames 16128-16711 the o2's just hover at 50mv or so.
    Dec 2005
    Regina, Sask.
    4,215
    Ok, I see that the O2's are not switching properly at idle. Set the idle to 750 rpm, then tune the Maf to get the fuel trims closer.
    Russ Kemp
    Nov 2007
    Huntsville, AL
    29
    Talking
    Thanks Russ K. I will set the idle to 750 and defiantly work on the MAF. The only reason I haven't adjusted the MAF was because I thought I needed bigger injectors and thought it would be a waste of time. But, I am going to work on that tomorrow. Again, thank you for taking your time to help me out Russ K and Bill.
    Nov 2007
    Huntsville, AL
    29
    I am also thinking about running a can of seafoam in a tank of gas. Maybe that will clean anything that maybe clogging the injectors.
    Oct 2010
    Houston, TX
    9
    Dont run seafoam, just take the injectors out and have them flow tested. Seafoam = not good.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Blitzmann View Post
    My gut tells me to agree.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Tuner TexasGMC08's Avatar
    Feb 2013
    Fort Worth
    102
    I am getting a P1174 Fuel Trim Cylinder Balance Bank1 as well! What is this fix???
