Results 1 to 8 of 8
Thread: 2010 silverado beta verison v8 to v4 mode
    I have a 2010 silverado, i am using the beta version to tune it. i shut off the displacement on demand and drove it for a day or two. i tried to turn it back on and it says enabled but does not actually go to v4 mode or show it on the dash indicator. HPtuner shows its enabled. anyone have a clue on this? i did a write entire calibration also.
    2002 Camaro SS, Twin S480s
    2006 Corvette C6, Twin Turbo
    1991 GMC Syclone, LS/AWD/AC
    28,312
    what does it do when you flash the stock file back to the pcm?
    will run the stock tune but will not go back to V4 mode.
    any word on this?
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Beta needs fixification.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    i did a stock write entire again and on the third time it worked. not sure but its good now. its probably just my truck. lol
    Advanced Tuner Bluecat's Avatar
    May 2006
    Catlettsburg, Ky
    407
    Dont forget the link between dod and cot... Cot cannot be disabled if you wan't dod to be enabled.
    rather than disable COT completely could you not just basically zero out the tables...
    Quote Originally Posted by cjg454ss View Post
    its because in V4 mode it wont spin for a 60 roll
    2010 Cobalt SS/TC aka "Cavalier SS" aka "Corsica SS" aka "Geo Metro ZR1"
