ok i have had this tune on my car for a few months now and it starts acting up here lately.
I did not have this issue at first but it seems to happen more now almost like the car has forgot the tune or has made changes to the tune (which with the J body ecm is impossible)
Here is a example.. Tonight i was going to my parents house and just cruising along at partial throttle low rpm i notice my aem wideband shoot to 17 afr and the car kinda had no power what so ever (but i did NOT try to do anything i just let off the throttle when this happened) then bounce back to 14 within a second. then it did the same thing agian.
Now friday night at work i was in the lot just idling for about 10 minutes and i look down my afr out of no where just shoots full 10 afr and the car was running like crap so i blip the throttle and its back to 14 no problem, then it did the 17 afr for a second then back to normal and once more it did the same thing to 17 then back normal.
I talked to my friend who helped me over the phone get the tune done and he knows his stuff. He said its just a J body ecm issue and i cant fix it. what do you all think?
Now it didnt do this at first but now it seems its progressively getting worse and worse. Odd thing is its not a daily issue. so what could be happening.
mods are
2004 ecotec motor
2002 ecotec ecm (stock in my car it was always a eco)
LE5 intake manifold
60MM bored throttle body
36# per hour saab green top injectors
AEM UEGO wideband
and basic stuff on top of this.
all did on the tune was
changed injector constant
ve tuned with 1 bar high and low rpm afr error %
My config file was provided to me from a friend whom got it from ryan aka imphat or now qwk ln2
i DO not have a log file at this time because i cant seem to catch it just right lol... but i will attach the tune...
