Results 1 to 9 of 9
Thread: Bootloader timeout, NO bcc
    Exclamation Bootloader timeout, NO bcc
    I am trying to read a 2003 chevy silverado 2500hd 6.6 duramax, when i try to read it it gives a boot loader timeout error, i have read that it is due to low voltage... i put 2 brandnew interstate batteries in the truck reading 12.6 volts with the engine in the run posistion, and it still throws the same errors... hell, ive even hooked up a battery charger and got it up to 13.5 volts, still the same problem
    one thing i noticed is when i am reading the computer, the vin comes up fine, but the BCC is blank, no ???? like on my old 98 camaro, just blank...
    i have scanned this thing with a snapon modis and cleared every code on it, i guess these trucks are known for having a few weird codes that dont throw a CEL, sily body codes and such i read are totally normal, anyhow, i cleared EVERY device one by one and tried again, same thing...
    any ideas?
    28,319
    Likely a pcm or wiring issue in the vehicle then.
    my friend has owned this truck since he bought it new from the factory, has never done anything to it... are there any logs i can give you?
    28,319
    Try reading in low speed mode.
    we are talkin in email as well... ive already done low speed mode, you said to try a bench harness, but how do i program the tcm?
    28,319
    If you cannot read the pcm you will not be able to program the tcm.
    if i bench read the pcm, and then do a write, how am i to ever get to the tcm? your saying i have to bench program the pcm, which makes sence, but then the tcm never gets touched...
    28,319
    Its unlikely that you'll be able to write to the pcm/tcm in vehicle if you are unable to read the pcm/tcm in the vehicle.
    ugh. should i just replace the PCM?
