I see in the tune there are tables for 1-3, 2-4, etc. Is this a skip gear feature and do I want to modify these for faster shifting also? I have the normal shifting quick and precise, very nice. What do you do with the skips?
They are a skip shift feature, but only when you are accelerating and let off the gas for some reason. You can but i wouldn't make them as aggressive as the rest of the shifts.
2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
2011 Ford Taurus SHO - stock with just a Tune
