Results 1 to 7 of 7
Thread: What VCM should I get?
    Aug 2005
    Midlothian, VA
    205
    Hello,
    I have a 04' Supercharged Monte Carlo and I am wondering if I buy a VCM what options should I get with it?
    Mitchell
    '04 Supercharged MC SS
    MOD LIST
    Custom PCM, Ram Air Hood w/ Air box, Intense MPS w/3.6", R/T DP with Ubend delete & HF CAT, LC-1 WB, GMPP Cat Back, Jacobs wires, 180 T-stat, & an Optima Red Top
    28,776
    Re: What VCM should I get?
    ??? are you talking about what options you should get with hptuners? A vcm is a term I think hptuners uses to describe what they tune ie pcm's but gm changed the name to vcm...so unless your strait up buying a pcm your using the wrong wording i believe.
    Aug 2005
    Midlothian, VA
    205
    Sorry, I am referring to what type of options should I get for my car?
    Mitchell
    MOD LIST
    28,776
    there really arent anything out of the norm available for your monte...if you want to get the enhance unit with the inputs/outputs for things like w/b a/f sensors, egt sensors, shift lights etc go with that...i dont really see a need for extra pigtails unless you loose one...1 & 2 bar isnt available to you so your pretty basic when it comes to options.
    Aug 2005
    Midlothian, VA
    205
    Thanks,
    I was wondering about the pigtails. How many would I need if I hooked up as much as I could? For the sensors and all?
    Mitchell
    MOD LIST
    Jul 2004
    1,579
    Most people only need one, for wideband use. If you are going to use other inputs or outputs, that share a pinout from the EIO connector, then you would need extras. I would say to purchase one and if you need more than you can purchase them at a later date. Or just build your own connector to the EIO, like I did.
    Aug 2005
    Midlothian, VA
    205
    Thanks for all of your input. 8)
    Mitchell
    MOD LIST
