Page 6 of 16 FirstFirst ... 2345678910 ... LastLast
Results 101 to 120 of 309
Thread: LNF New Parameters
  1. #101
    Quote Originally Posted by shabby View Post
    I don't see any changes in the kappa gmpp files, only some minor wastegate duty cycle. Are you looking at the cobalt gmpp files by any chance? They seem to have a lot of changes compared to the kappa ones.
    I am, only one I have :\
    Weird that their wastegate tables are so different than ours...
  2. #102
    Tuner 1080112520's Avatar
    Oct 2009
    Vine Grove ky
    96
    so a pressure of 2200 should do 60%. hmm ill look into the injector timing and pule width to see if i can change somthing..... hmmmm
    2009 chevy cobalt ss turd. to many mods to list and to many problems to fix...... errr previous owner
  3. #103
    Senior Tuner BackyardTurbo_FTW's Avatar
    Jul 2009
    East Suckburg, PA
    1,163
    Im running 50% E right now with modified injection timing and 2200psi of fuel pressure. No more TF file right now, all with HPT and less then 8ms IPW and never over 30% IDC.
    I tried the Fuel Mass Setting and I didnt like the way it ran, I have to put more time into that. Getting the Wastegate tables figured out took a lil time but I got it now. Nice to remove the sick spike down low, the car is incredibly more smooth and powerful once you can dial in the WG% to suit
    So far so good, everything seems to be working right!
  4. #104
    Oct 2009
    Vine Grove ky
    96
    yeah i am waiting for my guy in hawaii so i can tune him. Im gonna start with his car with the new parameters. lol..........
  5. #105
    Oct 2009
    Vine Grove ky
    96
    yeah i have several settings changed just for the first base start, i have the wastegate correction factor setting i hopoe to a good start ill see whaen i get contacted by my customer to start tuning lol
  6. #106
    Advanced Tuner 383_Stroker's Avatar
    Apr 2009
    258
    What is the value in the cells in the wastegate (duty cycle cor) table?
  7. #107
    Oct 2009
    Vine Grove ky
    96
    i changed the cells so theyed start slow and end up going to at a constant percentage of 280, ill see if this does anything if not then i can always change.
  8. #108
    Jul 2009
    East Suckburg, PA
    1,163
    280?
  9. #109
    Apr 2009
    258
    What i mean is.. what is that percentage? What does that number represent
  10. #110
    Oct 2009
    Vine Grove ky
    96
    lol.. yes in the wastegate correction factor map. I dunno if itll change anything. we will see, but i just did it to see what happens ...
  11. #111
    Jul 2009
    East Suckburg, PA
    1,163
    you can't command more then 100% wg dc. You should maybe go out and try some of this on your own car lol...
    Just noticed you can raise the Fuel Pressure to 32.8MPa or 4700ish psi lol..
  12. #112
    Oct 2009
    Vine Grove ky
    96
    i would if i had my tuner lol............ And you can set the settings for 327%. It might not do anything, but this is the whole point im doing it. (DUTY CYCLE CORRECTION)
  13. #113
    Oct 2009
    Vine Grove ky
    96
    And i did ask my customer if he wanted to do this or nt, he said well hell eyah, and i will be taking my time doing this. BUT IDO WISH I HAD MY TUNER SO I CAN WORK ON MY OWN CAR.
  14. #114
    Jan 2009
    569
    Quote Originally Posted by BowTieTillIDie View Post
    I am so lost I feel like a 5 year old in the Mall of America..
    If anyone gets this stuff squared away before this Sunday I would appreciate it ... Going to a circuit track for the first time this weekend and will have the chance to run an E85 Trifecta car with almost the same mods ..
    Working on it right now although it will take some testing to see what works best.
  15. #115
    Feb 2009
    417
    Quote Originally Posted by BackyardTurbo_FTW View Post
    I texted one of my LNF buddies saying... "Want 4700 psi fuel pressure". haha I noticed it right away too.
    Someone test it!.. j/k
  16. #116
    Jan 2009
    569
    That would trigger a low rail presure code LOL. Pump cannot support more than 3000 psi.
  17. #117
    I wish there was an E85 station somewhere around here... I'd burn 1/4 tank of it just going to fill up. Oh well, this should still give me a bit better boost control and maybe a bit better mid range eh?
  18. #118
    Jul 2009
    East Suckburg, PA
    1,163
    Yea, there's no point or need to run that kinda fuel pressure lol. Im not having any trouble with 1:1 E blend at 2200psi of fuel pressure. The Injection timing is key
  19. #119
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    I'm stuck at work and can't come out and play. lol.
    '12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
  20. #120
    Jul 2009
    Winfield/Ofallon MO
    600
    I'm afraid to screw with my tune, ever since I had a pro tune it with the combo I havnt touched it as I don't have the tune. My lack of knowledge owns me
