I need help with this, I have set up the system correctly (as per the ZZP instructions), and the fuel pressure is set at 42 base (from ZZP). The pump works fine, no leaks, the thing just won't stay running for longer than 2 seconds. ZZP has some pretty crappy instructions for installing this, and they will not help at all with the tune. Not even recommending what needs to be changed. I have used the Return Style Tuning Guide as my reference.
Pertinent mods are :
TVS
2.7"
93 pump gas
79# injectors
ZZP BRFPS installed as option 2 (removing stock in-tank regulator)
I have not adjusted the MAF yet, as the car won't stay running long enough for me to. The 79's are hard to find any concrete numbers for, and the only thing I could find online are the specs found at the following link, so these are the specs I used to set up the injectors. I am assuming that they are tested at the industry standard 42psi, but it doesn't say :
Racetronix 79's
This is very frustrating. My tune file is attached, but most people run either 60's or 80's so no one has any BRFPS/79's set up. Any help would be appreciated.
