Page 14 of 16 FirstFirst ... 410111213141516 LastLast
Results 261 to 280 of 309
Thread: LNF New Parameters
  1. #261
    Feb 2010
    The Desert
    480
    Quote Originally Posted by acesneights View Post
    Thanks, Ill look a lil more into it!
    Im just trying to get my car to hold 95% DC, it drops to like 75% AT LIKE 4-5k. I switched those tables over to GMS1, and tweaked a few things, so I hope that helps a lil. Should I raise the fuel pressure a bit, would that help hold it?
    Read the thread that gmtech started. I posted info on the PID boost controller and IAB posted on how to get the WG to hold. No, fuel pressure will not help with the WG.
    09 RY Cobalt SS Coupe - 19K miles - Bolt ons + 7163 ZFR, HP tuned on ethanol
    Sold - 09 SRTC Cobalt SS Sedan
    Totaled - 09 VR Cobalt SS Sedan
    Sold - 09 RY Cobalt SS Sedan
  2. #262
    Feb 2010
    The Desert
    480
    Chris,
    Is there anyway to include something in the cat warm up disable that stops the wg from fluctuating?
    Just curious, thanks.
  3. #263
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Cam tables help that. GMTech's work well. I think he posted them, make the cold and warm tables the same.
    '12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
  4. #264
    Thanks guys!
    09 Cobalt SS - 313hp 390tq
  5. #265
    I have my cam tables close to T2's tables. I set my limit to 300kpa and made the gain tables like GMTech's. I think Im goin to put my DAL table back to stock.
    This should help hold right?
  6. #266
    Jan 2009
    569
    Cat warmup disable works great. It is so refreshing to have a single switch work so well with this ECM. Most tuning aspects of this ECM are so complicated they require 10 tables to actually accomplish full control of any one thing.
  7. #267
    I really like having stock DAL tables and using MALT to control them. The car is so much more drivable. Using them on the GMS1 base I make more boost than I did with insane DALs and the "base" tune anyways. In fact, I'm going to finally order some sensors because I now peg my MAP for nearly the whole pull.
  8. #268
    Quote Originally Posted by Chris@HPTuners View Post
    Boost
    - MAP sensor Linear
    - MAP Sensor Offset
    - Prop Gain
    - Int Gain
    - Deriv Gain
    - Prop Gain Steady State
    - Steady State Boost Enable
    - Prop Max
    - Wastegate DC Correction factor
    - Wastgate DC Max
    - BOV Surge Limit Upper
    - BOV Surge Limit Lower
    would these allow me to force the bpv to stay open at light throttle to get rid of the funky surge the AEM intake causes at light throttle?
    2010 Cobalt SS/TC aka "Cavalier SS" aka "Corsica SS" aka "Geo Metro ZR1"
  9. #269
    Aug 2007
    503
    Quote Originally Posted by roadconetuning View Post
    Don't think so, this will only work at wide open throttle when there is pressure in the ic pipes.
  10. #270
    ah, i wasnt sure what the black box the bov line goes to does, didnt know if it went to a vaccum ball or what.
  11. #271
    Advanced Tuner black06g85's Avatar
    Jul 2006
    New York, New York
    277
    Fantastic, too bad the big turbo one we had got totalled.
    2006 cobalt (no more turbo)
    m62 2.7 pulley, E85, 79lb/hr injectors, 4-2-1 longtube header, airbox mod, stock catback
    1998 Trans am 5.3 iron block 317 heads 88mm turbo e85 105lb/hr injectors, twin 255's.... build in progress
    2014 wrx mild tune 18psi pump gas
  12. #272
    GMTech and IAB thanks for the words! Hold 100% BDDC all the way to 7k, running 21* timing no KR. However I do have about 3* KR between 4000-4500 rpm, but its not pulling timing. What could be causing this? I dont really want to lower the timing in that spot cuz I have it ramping up nice and smooth.
  13. #273
    Jul 2009
    2,305
    How much advance at 4k? Is that where your air load peaks?
    If it's only showing on one cyl, (prob #4) it may not be real. Try colder plugs if you haven't. I can't remember your setup right now. Mine likes NGK 3787's @ .032", some don't though.
    I log all 4 cyls KR separately and total retard.
  14. #274
    Jun 2008
    Baltimore, MD
    31
    I see the cyl #4 (only) KR often when at cruise conditions. I think one source is its picking up drivetrain noise when the load reverses.
    2008 Saturn Sky Redline
    Best 1/4: [email protected]
    2009 Cobalt SS/TC Sedan
    Best 1/4: 13.27@105
    Both HP tuned and all else stock.
  15. #275
    I have about 13-14* there i think. Maybe 15.
    Ill have to check to see what cylinders its kr in.
  16. #276
    I do need to get some colder plugs tho. Im still on stock ones
  17. #277
    Jul 2009
    2,305
    Try backing it down a degree and see if it cures it, sometimes once it starts KR it grows.
  18. #278
    But it doesnt grow, it only happens for like 1000rpms then stops, just randomly pops up to 3 then drops.
  19. #279
    what could be is causing the continious overboost here? i have my dals set at 255 in the 100% column, pressure limit set to 265. 4th and 5th gear is set like that for the clutch slip boost spike i had.
    '09 cobalt ss. hahn intercooler, intake, cp,catless downpipe, ottp stage 2 mounts, hptuners, gmpp 3bar tmap sensors, hybrid hp tuned
  20. #280
    Jul 2009
    2,305
    Back off the DAL's or MALT until you get the level of boost you seek. Perhaps the wastegate rod was shortened in the past?
