Hello. I'm having some issues with tuning my 07 Saturn Sky 2.4l. I recently built a turbo kit and been trying to get it tuned. I am running a 2 bar map sensor and GM stage 2 injectors (42#) from a 03 ION redline. I had a pretty good base map built for my stock 1 bar map sensor with no CELs or issues. When I put the 2 bar map in I started to have tuning issues and getting P0068 and p0106 causing it to go to limp in mode. Also having issues with the car falling on its face when trying to boost. I plan on running about 10 psi once tuned on pump gas. I have the config file and a log from a drive home if this helps. Any help would be greatly appreciated!
