Results 1 to 6 of 6
Thread: Cannot open a file that i could open last night?
    Jan 2011
    11
    I created this file, its the original backup.
    Now i cannot open it. What happened was i created this file, made 3 backups of it and converted one to 2bar map sensor and licenced it.
    Now that i want to go back to the original map sensor tune (this file) i cannot open it in HP tuners. I get this error.
    "Unable to open file"
    "Index was outside the bounds of the array"
    I tried to open it with 2.23 beta and also the 2.22 release and i still cannot open it.
    Have re-started laptop, uninstalled and re-installed.
    I need to go back to this old tune asap. can someone help?
    i cannot upload the file, its a .hpt file and its 4mb which exceeds the forum limit?? why is the limit smaller then the .hpt file sizes? i do not understand
    Every time i use HP tuners I learn something new! can it get any better then this?
    It ain't a skyline, but it will do!
    Jan 2011
    11
    i tried to zip them and upload them but i cannot???
    Jan 2011
    11
    I uploaded it to the web as i am not able to upload a hp tuners file as an attatchment.
    Here are both files, the original one i downloaded from the car and the 2bar modded one.
    How can i read and go back to the original one? I am using same pc and same software??
    www.skylinecentral.org/HP
    28,313
    The 33280 "original" file is corrupt. the other file(the smaller 3.3mb one) opens fine for me with the newest beta.
    Jan 2011
    11
    If i cannot go back to the standard map sensor then i need to get it working with the 2bar map sensor.
    when you try and start the car with this file it starts then stops. if you give it some throttle when you start it and keep the revs above 2000rpm it will run but as soon as it drops below 2000 the engine just switches off like you have turned off the ignition.
    How did that file get corrupted? i made 3 copies all do the same!
    cheers
    28,313
    I have no way to know how it got corrupted.
