I am trying to set up an LM1 to imitate narrow band on my 2002 Z06. The sensor has 4 wires, 2 brown, 1 light brown or tan, and a purple. The light brown shows 12 volts with the ignition key on which according to Innovate instructions should be the heater power wire. Two more wires should be a heater ground and a sensor ground and one more would be the sensor element connection.
I am trying to figure out the sensor element and being thrown off because according to Innovate instructions on a 3 wire sensor which they say to follow if one has a 4 wire they suggest the ground connection has less then 1 ohm resistance. When I tested the sensor wires with the ohm meter it was the light brown wire on the sensor pigtail that showed less then 1 ohm between the connector end and sensor threads. The others showed an open continuity? I need to figure out the sensor wires and any help or direction would be great.
When I checked the Service manual schematics it shows up as a 3 wire even though I input the serial number.
Carlos
