I'm encountering random 1 and 2 degree knock on my mildly modified Camaro and bone stock vette. I am not sure what is an acceptable knock. Maybe better stated, what is real vs false knock. The runs made are on black top roads. So what is your opinion are they road noise or real knock?
I have a 2010 Camaro with American Racing Headers with free flow cats, Corsa mufflers and a intake that put the MAF on a straight section. So they are really mild changes. Altitude is 5000ft. I followed the MAF part throttle and and wot throttle tuning that is from the tuning school. MAF definitely needed calibrating. At this time, I left the PE table stock even though the low 11's afr in WOT seem rich. But that is what the OEM called for. Anyway, the long term fuel trims were low so I decided to leave the stock speed density VE algorrithim at low rpm's rather than enabling the MAF down to a low RPM. I am not sure how to adjust the virtural VE anyway, but it appears to be still close from the logs.
So next on my agenda was to tune spark at part throttle. I was trying to use delivered torque at part throttle on the road. Before I could realy get into the spark tuning I did some test runs and noticed this knock. For fun, I even set the Camaro down to 10 degrees (in the part throttle section) as a test and still had a 1 degree blip. I attached both runs and the tune. I also included a sample wot run I did with the wide band connected. I did not install the wide band for the part throttle runs because I was not going into power enrichment.
I also attached my stock zo6 part throttle and wide open runs and noticed it had knock. By the way if you see the afr jump leaner on the vette 3k rpm into WOT that is probably because the flaps on the muffler opened up and the wide band was on the muffler tip. Eventually, I will install a bung on the vette. The Camaro has a bung after the driver side cat that I attach to.
I purchased/read the basic and advanced courses from the tuning school and read several fuel injection tuning books including Greg Banish's.
Sorry for the long post. I was trying to do a little pratice spark tuning before taking it to a dyno and blowing money because I am so slow. The stock knock is a concern. I understand the delivered torque method is not delivering repeatable data and I don't know how to change the virtual VE table. But these issues are seperate and not a priority versus determining what is accepatble knock from road noise.
