Page 16 of 22 FirstFirst ... 6121314151617181920 ... LastLast
Results 301 to 320 of 423
Thread: The LNF Tuning Guide
  1. #301
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by BackyardTurbo_FTW View Post
    I agree, but on the LNF we can't adjust that.
    Sorry I was thread skimming and I thought that Trifecta had been into that controller. If Vince has been into it, who knows what his own personal definition includes.
    Steve Williams
    TunedbyFrost.com
  2. #302
    A big thanks to BYT and the others who contributed to this thread. It should be a sticky!
  3. #303
    Aug 2008
    22
    OK Just made it through this thread.
    I currently don't have the GMS1, but I will probably buy the sensors. Am I ahead to do a write entire of a stage 1 tune then start working from there, or am I safe to work from my stock tune?
  4. #304
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    You can use the stock tune if you calibrate it with the GMS1 sensor data when you put them in, it'll boost harder than GMS1 as the base tune lacks some turbo protection the GMS1 file has built in (that we can't access).
    '12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
  5. #305
    Would it be a good idea to ramp the Max Airload Torque Table down a little leading up to the shift points in an automatic to help the transmission survive?
  6. #306
    Aug 2008
    22
    Still debating whether I start with my own tune or start with a GMS1 tune.
    Does anyone have a 2008 Sky Redline automatic GMPP tune? (Or Solstice automatic would be fine I'm sure).
    Either way, I need a GMS1 to look at whether I write entire it or copy parts of it...
  7. #307
    Jul 2009
    2,305
    I ran a stock tune on the GMPP 3 bar sensors with modifying the scaling for the 3 bar MAPs. Boosted better as the stock file lacks all the turbo protection stuff in the GMPP file.
  8. #308
    Aug 2008
    22
    Well a 6.9 60-100 doesn't seem all that great to me. It's really freakin hot out, but I was hoping mid-5's...
    I guess I have a long way to go
  9. #309
    Feb 2010
    The Desert
    480
    Quote Originally Posted by RedSkyWV View Post
    That's not bad at all. Try going WOT at 55-57ish to let the trans kick down and to allow the tb enough time to open. Mind posting up your tune and the log for your 60-100 run?
    09 RY Cobalt SS Coupe - 19K miles - Bolt ons + 7163 ZFR, HP tuned on ethanol
    Sold - 09 SRTC Cobalt SS Sedan
    Totaled - 09 VR Cobalt SS Sedan
    Sold - 09 RY Cobalt SS Sedan
  10. #310
    May 2011
    26
    How are you guys measuring the 60-100 time? say start at 50 and have full boost by the time u reach 60 or 60 and pin it? i think that's why there's such a huge gap between the red's time.
    i ran 5.4 tonight 60-100 but that's with starting at lower speed in 3rd gear
    Cobalt SS Turbo - GMS1, MPX Catted DP, MPX Catback Exhaust, K&N SRI, Custom HP Tune
  11. #311
    Jul 2009
    2,305
    Nail it at 53-55 so the throttle is at 100% at 60. My best was 4.4 sec stock turbo on 47% ethanol with IAT2's in the upper 30's last fall. Traction in 3rd was an issue.
  12. #312
    Dec 2009
    western nc
    36
    didn't know you you guys were hitting it that soon! That just dropped half a second for me hiting it at 53mph! 6 seconds flat at 87 degrees ambient temp and humid as hell, K&N drop in and tune only on 93 octane. Not bad for the first week of tuning thanks to you guys I am so hooked.
  13. #313
    Jul 2009
    2,305
    It's the heat and humidity. If anything you should have gained a bit as you are 100% on the throttle plate when you go through 60 mph.
  14. #314
    Aug 2008
    22
    Quote Originally Posted by Iam Broke View Post
    Wanna hook me up with a similar quality tune for 93 octane?!? I really would like to get down close to 5 seconds, I'd be thrilled in fact! I have stock turbo, full catless turboback.
    It was 78 and high humidity for my run yesterday. I punched it by 56-57mph, so I don't think my number is far off from what you would have seen on my tune.
  15. #315
    Advanced Tuner silverbullet08's Avatar
    Dec 2009
    Houston, TX
    453
    It takes a lot of fine tuning and logging to make times that low. Its not like you can just throw a tune that one car liked onto another car and it work. My fastest i could pull was a 4.7 with the clutch slipping until about 68 or so. My stage 4 should be here tomorrow... maybe i can pull some faster times
    HP-Unlimited Tuning and Custom Fabrication
    Houston area performance parts dealer
    MD800 Mustang Dyno 713-560-3889 Taylor
    2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
  16. #316
    Aug 2008
    22
    Oh I know there's no such thing as a universal tune -- at least not an aggressive one. I just can dream
    As I continue to read here I'll get better, sub-5 seconds seems to be relatively common so 5 seconds isn't impossible for me.
  17. #317
    Jul 2009
    2,305
    Elevation, temperature & humidity all play a big factor. I'm at 700' above sea level. How 'bout you?
    I do email tune & log corrections BTW, as do others on here.
  18. #318
    Aug 2008
    22
    I'm about 1900'
    I may take you up on a lookover after I do a little more work on my own. I would love to know what's good and what's bad. I'm mostly garnering information from these various LNF related threads though. I understand the concepts but I'm not too brave nor too experienced with tuning.
  19. #319
    Feb 2010
    The Desert
    480
    Which is why I told you to post a log and tune
    Pointers
  20. #320
    This tune is what I hope is a decent starting point for a somewhat mild tune for a 2009 Solstice GXP with and automatic. I’m trying to be a little easy on the transmission. I’m wondering what effect ramping the Maximum Air Load Torque down ahead of shift points would have as apposed to straight lining. Would ramping it down reduce power ahead of the shifts?
    I included the stock read for reference and any input would be appreciated.
