Results 1 to 20 of 23
Thread: Disable VATS - 2007 Cobalt Swap into Buggy
    Sep 2008
    Portersville, Pa
    289
    I have a customer who swapped a 07 Cobalt engine into a custom dune buggy. I'm not sure which Ecotec this is but wanted to know if the VATS can be disabled from the OS/General/VATS1 & 2 settings and is there anything else I need to be aware of?
    He is indicating the engine starts and runs for 3 seconds then quits. I am assuming this is VATS related but won't know until the buggy gets to the shop.
    Is there anything I should be aware of here? I never worked on one of these swaps. I did search and read here that there is no VATS disable for LNF's...
    Thanks!
    Mike
    28,315
    Can you post the file in question? 07 Cobalts used several different pcm's.
    Sep 2008
    Portersville, Pa
    289
    Not at this time. The vehicle won't be arriving for a few hours. I was trying to be as prepared as possible.
    Are there any 07 Cobalt PCM's that can NOT have the VATS disabled?
    Thanks for the lightning fast response!!!!
    28,315
    The vats tables(and patches in the case of E37) are already there. In some cases theres an additional starter check patch we can add but I would need the file to see if its already added.
    Sep 2008
    Portersville, Pa
    289
    So assuming that this requires no "starter check" patches would the procedure be:
    1. Set OS/General/VATS1 & 2 to disable
    2. Perform a "Write Entire"
    3. Start the engine and tune away?
    Sep 2008
    Portersville, Pa
    289
    The steps I listed above worked like a charm. No patches needed.
    Thanks Bill for the help and fast responses!
    Apr 2016
    5
    I?m trying to do the same thing for a 07 Saturn Ion I dont see vats under General is there something different I need to do?
    Dec 2008
    Nevada
    4,452
    can you post your current tune file
    Apr 2016
    5
    Quote Originally Posted by cobaltssoverbooster View Post
    So got an answer thanks hptuners
    I was viewing the file as basic not advanced all better
    Dec 2008
    Nevada
    4,452
    i was going to say that was likely the issue but also i needed a file to open so i could find its location and report it.
    May 2020
    Hey I have a 07 Cabolt that I’m needing to vats delete and I went into os and disables vats patch but still nothing what can I do to get this straightened out any help would be greatly appreciated
    1,608
    What do you mean by still nothing?
    Do a write entire instead of calibration
    Aug 2022
    6
    Noticed this thread, while searching for a solution for a customer
    I can?t seem to find where I can look up and verify if for example I wanted to disable the immobilizer on a 2007 Chevy cobalt.
    Is there somewhere on the product support page where it will show things such as the various faecium?s in if immobilizer delete is a option?
    If this is a option and I go to do it, do I do just a calibration or right? The entire drive? Also, I noticed in the vehicle I am not able to communicate with a Immobilizer system. A.k.a. the vehicle theft deterrent module, which is why I?m wanting to disable that as we?ve already ordered one coil because the other one was damaged by the owner of.
    I hope I?m going about the proper way rather than creating a new thread. From reading, I?m guessing I?m going to have to get a photo of the vehicle PCM?
    1,608
    Quote Originally Posted by HP72 View Post
    No instructions available from HPT to do much of anything for specific ECM's. You have to dig through the forums (or youtube, classes, etc,) for most of that type info.
    You can disable the VATS on the 2007 Cobalt, but I don't know all of the steps. Typically it will be write entire, with vats turned off and possibly some starter diagnostics disabled also.
    28,315
    depends on the ecm type, if its E37 or E67 the vats patches are located under the os tab, there is a description in the os tab for disabling them.
    If its an E69 or E77 ecm found in some cobalts our software cannot disable vats in those applications. Either way check os tab and system tab, those are the most common places for vats switches.
    1,608
    As far as I know the E69 ECM was only used in the 2008-2010 Cobalt SS/Turbo/LNF (It's the one that I have). I don't know about the E77. Looking through some post on here, it looks like maybe at one time (2013 or so), HPT was mislabeling the E69 as E77.
    1,608
    Or is E77 the unsupported 2005 Cobalt ECM?
    Aug 2022
    6
    ok looks as if I need to get ecm info.
    I thought HP Tuners use to have it here you could see what options were available for the certain YM&M vehicles before purchasing the credits? So is it now you pay for the credits to find out if it can or not? /I hope not as this type of modeling for sales could drive sales and tuners likewise away. Maybe I'm misunderstanding things? I hope not.
    1,608
    HPT has a supported vehicles list but it doesn’t go into every option/table available for that donor. Maybe a support ticket with HPT will confirm vats option. I’m 99% sure it is available for any 2007 Cobalt since it’s used a lot on the DF Kit car and is asked about on that forum from time to time.
