Car runs fine but the idle often goes from 850 t0 1300 or so. Sometimes stays at 1300 (or so) until car totally stops.....I did not tune it, had another guy do it....as I said the car runs good but the idle stinks....any advice?
'97 Corvette with 6.2L L92, L76 Heads, Performance Cam (.610 int/ex, 242 deg dur), 90mm TB, 38lb inj., long tube headers, Racetronix fuel system upgrade, aftermarket air intake.
No suggestions?
Airflow tables my friend. RAF is messed.
Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
618/618 motor
906/862 spray
Caterpillar 50 Forklift- Duramax swap
