2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
2011 Ford Taurus SHO - stock with just a Tune
I have a chance to get a 6L80e and need to know if it will fit behind a Gen IV 454 big block Chevy bored and stroked to 489 with aprox 560 ft lbs and 530 hp? What will I need to fit it? Flex plate, torque converter, internal beefing, rebuild ect.? I am planning to put it in My 67 Impala.
Search for info on here posted by "thesubfloor". He runs an LS7 Vette that runs hi 9's lo 10's NA with a [now] built 6L80E. Well over 100 runs on the same build.
Very impressive performance from the trans Chris. Sorry to hear about the motor exiting stage left.How many runs on the motor? What let go?
There you go trendsetters: 280+ runs on a 6L80E. With ~700Hp at the flywheel turning hi 9's lo 10's. And super consistent bracket times to boot.
Just like PG's, TH400's, 4L60's blah blah didnt hold any power until they were toughened up by the aftermarket and dedicated racers searching for results.![]()
Stock trans here at 30k been through 30-40 bottles and ditched that and now been boosted for a month or 2.
https://www.facebook.com/tuningbyshanehinds
[email protected]
2009 G8 GT [email protected] 1.60 - Sold
2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
2013 CTSV wagon 9.21@151
2015 C7Z bolt ons 10.0
I found that the durability of the 6L80 is actually pretty good. Mine lasted a LONG time before having to replace it.. I just got a new one from these guys https://reman-transmission.com/trans...des/?code=6L80 and she works like a charm. Just had to take it to the shop and have it installed and now im sittin pretty![]()
