Results 1 to 10 of 10
Thread: Speed Density Trim dialing failure
    Sep 2005
    402
    My scans:
    I click Average, Load all Data, then:
    As you can see I subtracted the Primary VE vs RPM vs MAP
    from the VE, LTFTs %(Histogram 3)
    as instructed by the old tutorial: http://www.wnyym.com/newbie/tuning_new.htm
    and it throws my curve way off, I have a huge spike in my tables/cells now!!
    Am I doing it right???
    Im trying to dial in the Speed Density Trims
    Tuner kabbott's Avatar
    Sep 2004
    Ba co. Md
    121
    In Scanner\average-load all data-right click-select all cells-copy.
    In Editer\open ve table-right click-paste special-add
    You want to add,if ltft's are negative(subtracting fuel)you want to add
    the negative number to lower ve at that cell.
    If you find that you keep overshooting(which i did)you can use paste secial-multiply by %-half.
    2000 Impala 3.8
    4T65Ehd 3.29
    VCM ID:7DS739259ui
    VCM OS ID:9387047
    Senior Tuner S2H's Avatar
    Apr 2005
    Schexnayder Racing - Arnaudville LA
    4,387
    Quote Originally Posted by kabbott
    its not an add function
    Its a % so its always Multiply by %
    as you get closer ... then you can do multiply by % - half
    and I actually prefer last value when doing LTFT...seems to get me there quicker
    -Scott -
    May 2005
    Conway, AR
    347
    You should be able to add?? When tuning fuel trims, they are a % and so is the VE table. So why couldnt you add % to %? I know on something like the MAF curve you would do %.
    Chris
    2009 Silverado Crew Cab 5.3L, stock.
    Sep 2005
    402
    hm
    so how do I find those -2 to +2 LTFTs?
    like this:
    "In Scanner\average-load all data-right click-select all cells-copy.
    the negative number to lower ve at that cell."
    The guide says (-) is Rich and (+) is Lean
    I think I understand what you mean.
    This is the only place I've been allowed to post my scans.
    Sep 2005
    402
    my ve ltfts are saying +16
    stfts are +20
    i dont like that.
    no timing retard
    max of 40 timing
    The V6 doesn't have the same fuel trim cell operation as the LS1.
    There was post here someplace about the V6 trims, i'll try to search for it.
    Chris....
    I count sheep in hex...
    28,767
    28,767
    ahh, that whole thread was posted before i even had my gtp, no wonder i missed it
