So this is the situation.. I have a 84 Silverado.. I recently put in a LQ9, with a 4L80E behind it. I have 35 inch Mickey Thompsons, and 3.73 gears.
The problems- First off, the speedometer is way off. I input my gears and tire size, and then I drive it and it says I barely get up to 20 mph and it will never shift, so I had to put some bogus numbers in for the trans just so I could drive it around.
Anyways motor problems, When cruising around like 60 mph and the trans is at like 2,200 the afr runs aroun 13.9. It runs real good it feels like. But at idle, the afr is off the charts lean, and when I take off it stays real lean until what it seems like I hit a sweet spot and the afr jumps to 13.9 and it runs good with good response.
Questions - How do I fix this? lol I'm really new to tuning, trying to read up on it as much as I can, but whats the best way to give it some more fuel and get the afr where it should be, and would this fix the whole, having to wait til it hits the sweet spot to get it running good? I have a AEM wideband but I don't have it hooked up to my hptuners yet. Any help or info would greatly be appreciated.
Thanks, from a newbie
