hi guys,
I’d like to receive one good advice from you.
I ordered to Golen enigne one 440ci LS7 short block.
The OEM one was seriously damaged.
It will be fitted with Kooks long tube headers, CAI, Katech torquer camshaft, fast 102 manifold, stock LS7 throttle.
The question is:
Per your experience, stock LS7 Bosch injectors are enough or they should be updated?
(they should be rated at 39 lb/hr according to Bosch:
http://www.boschdealer.com/index.php...products_id=35 )
or it's better to change over with some bigger ones? in that case, any p/n reccomended?
thank you
bye!
