Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
618/618 motor
906/862 spray
Caterpillar 50 Forklift- Duramax swap
Looks like GM left a lot on the table with the 5.3 engine/tranny. I just bought a new 2011 5.3 Silverado. I don't like voiding the warranty but sure itching to tune it.
transmission, torque management, stall torque mgmt, enable RPM / disable RPM
Are you using 2.23?
2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
Attached is my most recent tune with some of the changes suggested here. I had to go a little richer on the PE table due to KR on the log.
The only TM changes I've made so far is the Max Tq tables and the Stall Enable numbers. Let me know what you guys think.
Also, one thing to note. When doing the WOT runs, the scanner was only showing 84% TPS. When looking at the PE Enable table, the values were all set to 87% (before I changed them). So does this mean my truck was never entering PE? Why is it only showing 84% at WOT?
Thanks a lot for the help so far everyone. I've done all of the engine tweaks and some trans tweaks (shift speeds [mph], max enable TM) but now I'm ready to adjust actual trans shift speeds, shift pressures, and any other trans parameters.
I'll attach my latest tune so if you guys could look it over and make any suggestions, specifically for the trans, I'd appreciate it. Thanks again!
bump - great thread
2003 Silverado SS -6.0L - 4L65e - AWD
2008 GMC Sierra CCSB - All stock
2011 Chevy Traverse
when u tune low octane and high octane timing advance tables how does the computer know which one to use?
am i supposed to only mess with the high octane settings im running 89 octane
618/618 motor
906/862 spray
sorry i didnt put this is on a 2006 5.3 z71 still the same correct?
with catback and cold air intake
thanks for the quick response
618/618 motor
906/862 spray
at WOT im seeing 25-27 degrees timing on the stock tune and when im commanding 16 on the high octane tune and 11 in the low octane advance. why?
