2.23.534 was released on 3/7/12
2.23.530 was released on 3/1/12
ie 4 new builds since 3/1
Hows 2.24 going Bill? Also can't you make the beta window not expire after 30 or so days?
Contact support.
'12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
I hate to be "that guy" but I was wondering what the time frame is to edit the maps? Or at least how long it generally takes to go from crack to code....
http://www.hptuners.com/forum/showthread.php?t=11363
We are at step 6.
i just purchased a sonic 1.4 turbo, and cant wait to start hp tuning whit it. it def needs better throttle response, more boost, and of course mpg's. keep us updated and great work Bill and everyone at hp tuners. thanks
(sold)97 regal gs,L32 swap,vs cam,zzp fullsize ic,2.9,42.5lb,lq4 maf,zzp shift kit,zzp polly mounts,4" intake,SD headers,fp rewire,stage1vb,alt rewire,wrapped crossover pipe,160tstat,AL103's,3"exh,hp tuned.286whp 329tq(mustang dyno)
(sold)2012 Sonic 1.4 turbo 6mt: (sold) 2005 cts-v fbo, tune:
2016 ATS-V A8, tapout tuned.
Very excited for you guys to release support for this car, just bought a 12' Cruze Eco. OEM tuned with low boost, 87 octane = lots of potential lurking! 3100 lb car makes a good power to weight ratio a lot more attainable too. 300 fwhp/40 mpg??? Wishful thinking
Just sent email to support@...
I just got a Sonic 1.4, came off the transport Wed, build date 3/14. Very interested in mild tuning.![]()
I have been tuning these for the last 1.5 years and 175whp is realistic or 200hp / 220lb-ft at the crank. I am currently running 23 pounds measured at the intake manifold (around 25psi boost from the turbo) on 93 octane fuel - ported intake manifold, ported throttle body, K&N Typhoon intake and making 196hp (engine power, not wheel power) at 5200 rpm. Strapping a bigger turbo on it won't make any more power unless you can run more than 23psi at the manifold (you can't do this easily- it is a hard limit in the ECM) so you need to look next at DP,cams, exhaust manifolds, larger displacement, etc to get any more out of this motor (or run nitrous, meth injection, etc). The fuel system is also maxed out at 200hp (100% IDC at 11.8:1 at 200hp @5200 rpm), so no more fuel to support more power on E85 or nitrous unless you upgrade injectors.
That said, the car is pretty fun to drive with 200hp
Cheers,
Brian
2011 Chevrolet Cruze LT: 15.110 @ 89.380 MPH
Vermont Tuning LLC
1806 Sweet Hollow Road
Sheldon VT, 05483
Ph: 802-393-7305
email :[email protected]
Website: www.vtunersaabs.com
www.vtunerperformance.com (Now Live!)
It is difficult to measure the difference since there are many variables including driving styles, but with the ported manifold it may have a 1-2 mpg hit at highway cruising. Currently in 40F weather my 1LT automatic does 35-38 mpg at 65 on the highway with cruise control on. I never saw better than 38 before tuning or modifying it though. The baffles on the stock manifold appear to aid low speed fuel/air mixture, but definitely restrict high end power.
Cheers,
Brian
Vermont Tuning LLC
Sheldon VT, 05483
Ph: 802-393-7305
