Results 1 to 20 of 23
Thread: Scan 96-97 LT1
    Feb 2008
    Sikeston, MO
    173
    Scan 96-97 LT1
    I'm trying to remember, I thought I had saw a thread that said HP Tuners could scan (not write) a 96-97 LT1 vehicle. I was hoping somebody could confirm, I'm about to expand into them and need to make sure I have the scanning solution lined out.
    Thanks!
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    The scanner connects and scans just fine.
    It was a long time I tried and don't remember how many parameters you can scan, or if you can log useful PID's and make histograms for tuning purposes.
    I'm going to have a LT1 in my hands in a few days, I'll post results.
    Aug 2010
    Montreal, Quebec, Canada
    42
    I successfully scanned a 96 OBD2 LT1 with HPTuners last week. You won't be overly excited with the number of fields available though.
    Cheers,
    Brady
    Feb 2008
    Sikeston, MO
    173
    Thanks! I understand it will be limited, but if I can log MAF and WB at the same time, I'm good to go!
    Nov 2009
    Pegasus Galaxy
    919
    MAF Hz isn't supported, at least in a 97 Vortec Pickup I scanned yesterday
    I really really miss a good scanner for 96-97 LT1, MAF tunning would be a lot easier
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    here is what I have used
    The 96-96 LT1 Pcm works good
    but the scanning is very limited without a Snappy or Tech2
    on the other hand 94-95 PCM swap with OBD1 Datamaster will show you all the major players
    BTW SEMA 05'
    Steve Cole and his engineer form TTS had a demo on display of the Datamaster OBD2 for LT1s,
    I called several times after SEMA 05
    they said it was not ready
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
    Feb 2008
    Sikeston, MO
    173
    Quote Originally Posted by Montecarlodrag View Post
    Just being able to scan MAF at all was a big help! Unfortunately, no histograms means it wasn't nearly as efficient, but I made it work! However, not fond of it and I don't think I'll be doing any more 96-97 unless someone REALLY wants it done ($$$).
    Mar 2006
    sunny So Cal
    292
    Sorry bout the lack histograms
    been doing them for so long....
    pop in the first cal and I'm 90% done.
    beside most the big dawgs get switched to 94-95 computers and use TTS Datamaster to log
    NotoriouSS TAD
    Tuner Ricardo's Avatar
    Jul 2011
    5000 ft ASL
    79
    What about O2 sensor data?
    Do you knbow if the scanner displays it?
    Ricardo
    1996 A4 FBody with LS7 swap
    Feb 2008
    Sikeston, MO
    173
    Quote Originally Posted by ProTools4 View Post
    How hard is that switch?
    Nov 2009
    Pegasus Galaxy
    919
    Quote Originally Posted by GregRexAdams View Post
    It takes 5 min to do it.
    Swap the PCM for a 94-95 unit, disable a few codes, then tune it
    Plug and play, No wiring, no other mods needed.
    9 sec Montecarlo SS
    Nov 2009
    Pegasus Galaxy
    919
    Quote Originally Posted by Ricardo View Post
    Yes it does.
    But as Greg said, no histograms, mening you can't tune MAF or VE with copy-paste or paste special-multiply by %
    Any tunign you do using O2 data needs to be done 100% by hand
    No MAF Hz
    No AFR Error (because no AFR Commanded PID)
    No histograms
    That's why
    9 sec Montecarlo SS
    Could i do this on a 96 corvette?
    Sep 2010
    webb city, mo
    505
    what are you guys using to tune the 94-97 cars with? Tunercat? or something else?
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,215
    Yes, I use Tunercat for the 1996-1997 LT1/4 cars and scan with Hp Tuners.
    Russ Kemp
    Sep 2010
    webb city, mo
    505
    Here's a reply i got from Tunercat a while back when i asked if i could tune a '96 car for a buddy with their software....where are you guys buying your TC stuff from for 96-97 cars? i'm not looking to spend an arm and a leg to maybe tune 3 cars and put this stuff on the shelf.
    Thank you for your e-mail.
    No, our LT1 tuning kits do not support the 1996 - 97 OBDII LT1 cars, only the 1994 - 95 OBDI cars. The OBDII cars require a completely different setup. To tune the OBDII cars you'll need our OBDII Tuner program. The OBDII Tuner program comes complete with powerful tuning software, an OBDII interface converter and all the cables necessary to connect your PC to the vehicle. While we continue to do the development work on the OBDII Tuner program we don't sell this program directly. The OBDII Tuner program it is currently available from three sources.
    1. A low-cost version is available through JET Performance Products (www.jetchip.com) as the JET Dynamic Spectrum Tuner. This package comes complete with four licenses to tune four different vehicles. Additional licenses can then be purchased for additional vehicles.
    2. The real-time version of the OBDII Tuner program which allows you to do real-time tuning (while the engine is running) is available from Craig Moates (www.moates.net) when you purchase their Roadrunner emulator (which is needed for real-time tuning).
    3. A professional version of the OBDII Tuner program which allows you to tune an unlimited number of any of the vehicles currently supported by the OBDII Tuner program is available from Wester's Garage (http://westers_garage.eidnet.org)
    Best regards,
    TC
    Oct 2008
    297
    Quote Originally Posted by 2000_SS View Post
    tunercats sold out the rights to tunercats obd2 tuner to jet tuner, so those of us that had tunercats obd2 can and still get obd2 updates from tunercat but no new sales from them,, but i think you can still get it if you go through moates and buy there ls1 roadrunner kit, then you can get the obd2 cable from tunercats but it will cost more than what the rest of us paid years ago for tc obd2 tuner
    2010 camaro L99, Magnacharger TVS 2300, 415ci LS3,Kooks long tubes, yank ss3200, 3.73 rear
    Nov 2007
    MI
    686
    not entirely true. On the Impala SS your tach will read double after an OBDI swap. You need to buy a multiplier box to get it to read correctly. Also, don't forget the knock sensors need to be swapped as well if you plan on retaining them.
    2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
    Nov 2009
    Pegasus Galaxy
    919
    Quote Originally Posted by GPGTP View Post
    I have not swapped any Impala, but Fbodies work with stock knock sensors and no other changes than the PCM. I have done a few and the knock sensors, speedo and everything works good.
    9 sec Montecarlo SS
    Nov 2007
    MI
    686
    Yea I had to find out the hardway. It's strange that it works with the f-bodies and not the impala, doesn't make sense to me since they use the same pcm
