Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: 880/900 Dyno Log
    Nov 2005
    Houston, TX
    3,968
    880/900 Dyno Log
    I crashed the dyno competition of a neat Mustang event http://www.svtvstheworld.com/ last night at http://autoadrenalineperformance.com/. Nice bunch of guys and they were able to squeeze me in. It did pretty much what I expected. First pull was on 18#, second run I guessed on the EBoost shooting for 20# but only got 19# and it was pretty fat, like low 10:1's. Only had two pulls so had to stop there. No tune changes were made at all. Peak TQ just after 4500 and HP noses over above 6k which I would attribute to the 2.5" downpipes. I would have liked to see 900/900 but it'll just take another pound or two of boost. In any case it was enough to be king of the event.
    I'm #6
    I found out later that night the I would have had $100 coming to me if there had been enough (three) entries in the turbo class. Oh well.
    851/878 on 18#, 879/899 on 19#
    Attached are the log of the 19# pull and the tune as well as the config and vcm scanner file. Not sure you will be able to see the AFR/AFR Error without it.
    Setup is 408 iron block with 317 heads @ 10.2:1, 231/329 614/621 on 118+2, TTIX base kit w/ 57mm turbos, Alky Control dual nozzle meth, FIC 1k injectors, no cats, Corsa Sports.
    Bill Winters
    Out of the LSx tuning game
    Dec 2008
    Houston, Texas
    129
    Nice numbers, good looking graph!!!
    Jun 2008
    Charleston, SC
    969
    looks like you pegged 512 limit at 6500 rpms
    Nov 2005
    Houston, TX
    3,968
    It pegs the dynamic airflow but that doesnt stop the SD from doing its job. Maybe if I logged VE airflow it wouldnt max out?
    Bill Winters
    Nov 2005
    Houston, TX
    3,968
    Quote Originally Posted by R0G3R View Post
    Thanks. I like how the tq looks but not how power drops off before 6k. Its either the turbos or 2.5" downpipes.
    Bill Winters
    5BA8
    3,640
    Quote Originally Posted by 5_Liter_Eater View Post
    Thanks. I like bow he tq looks but not how power drops off before 6k. Its either the turbos or 2.5" downpipes.
    What do your airflow numbers look like when it noses over? Timing? A/F?
    email=[email protected]
    Nov 2005
    Houston, TX
    3,968
    Airflow continues to climb. AFR on 19# was fat, mid to low 10's. 14 degrees.
    Bill Winters
    Jun 2008
    Charleston, SC
    969
    20 bucks says you are at the limit of the turbos, but hey, 450whp from each turbo isn't bad for 57mm wheels.
    time for some gt35's or 6262's should be good for 1200whp
    Nov 2005
    Houston, TX
    3,968
    I think thats the case. Its got a little more in it, I think I can get better peak numbers but it will continue to nose over. No upgrades planned in the near future.
    Bill Winters
    Apr 2009
    613
    Congrats should be a fun street car!!
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
    5BA8
    3,640
    If it's running out of airflow, you can tune it to climb instead of nosing over. Ramp the fuel out, and the timing in. It'll climb.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Way to go! :bigclap:
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    nice job
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    baaa what do you know....
    But you are correct!
    G-FORCE Motorsports
    1941 CR 129 Pearland TX 77581
    281-993-5451 PH 281-993-5421 FAX
    www.gforce-tx.com
    [email protected]
    PCM Tuner LSX and SCT <-> How Much Force Can You Take??
    2009 CTS-V 630 RWHP 10.90 @ 129mph
    Nov 2005
    Houston, TX
    3,968
    I guess but ramping in timing and ramping out fuel (leaner than low 11's) is not what I want to be doing at 6000 RPM and ~20# of boost.
    Bill Winters
    5BA8
    3,640
    Quote Originally Posted by Mike@G-Force View Post
    Not much, but I did spend the night at a Holiday Inn LOL
    My favorite line is "I learned it on Hot Rod TV" LOL
    5BA8
    3,640
    Don't be skeered. You're way past peak torque, and peak cyl pressure.
    You mean a engine uses the most fuel at peak tq???
    G-FORCE Motorsports
    www.gforce-tx.com
    [email protected]
    Aug 2010
    Roswell, N.M.
    1,956
    This thread should be labeled an eye-opener.
    618/618 motor
    906/862 spray
    Nov 2005
    Houston, TX
    3,968
    Why's that?
    Bill Winters
