Hello everyone.
I need help. I'm running a 2bar os on a 0411 pcm, stock ls6, twin turbo, 115lb injectors on e85. Scroll to frame 3380 and take a look at the map (kpa) and the injector duty cycle. My boost is a solid 5psi on the gauge but the map is reading 200kpa. What do I have configured wrong? It's plenty rich but I need to figure this out before I lean it out. I just got this combo up and running.
Map sensor gm 12569241
I hope I posted enough info.
Thanks for the help.
Steve
edit: This problem exists scanning with laptop or mpvi
