Results 1 to 8 of 8
Thread: TCM not found
    Feb 2012
    Oil N Gas Territory
    15
    TCM not found
    have an issue with 2010 camaro im running beta 2.23 when i try to write to ecm i get error that says (TCM not found Flashfile requires a TCM please load file that is compatible with this vehicle or rectify TCM communication issues) my TCM op system is 2425065 car is a 2010 camaro with auto. Please help. is there some kind of way to just update or get rid of this beta? i suspect or have been told thts my prob.
    28,319
    disconnect the battery for a few seconds to reset the tcm which likely didn't reset properly after being read.
    Feb 2012
    Oil N Gas Territory
    15
    ok will try thanks. it always fails on step 2 of writing.
    Feb 2012
    Oil N Gas Territory
    15
    ok that got me through but i still have an issue check engine light on code is unknown PO23F
    Feb 2012
    Oil N Gas Territory
    15
    i have a stealth A1000 & i cant figure out how to trick the ecm to not throw fuel pump codes. the pump is stand alone as far as power is concerned.
    Feb 2012
    Oil N Gas Territory
    15
    i also installed a return line. any advice on what to do to keep the check engine light off
    Jun 2012
    Pirate Ship
    93
    Often found it easier to pull the #19 TCM fuse in the fuse box under the hood for a few seconds
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    To tricky1...
    Unplug the FPCM and disable the P069E code as well as the loss of communication with FPCM code. Done.
    http://www.dsxtuning.com
    Just say no to bull s***.
