Results 1 to 20 of 21
Thread: 07 zo6 H/C/I
    Apr 2012
    20
    07 zo6 H/C/I
    Hey All,
    I'm looking for a very choppy idle but when I lower my timing/idle/overspeed settings, exhaust poping after 2400rpm in between shifts. Let me know what you guys think.
    P.s Car made 607/533 dyno jet
    Thanks.
    Apr 2012
    20
    wow really nobody knows?
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Need a bit more specific description. The exhaust pops between shifts? Sounds like DFCO or a lean issue.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Apr 2012
    20
    under normal driving anything higher then 1500rpm backfire/minor poping sound. Do you see anything wrong with my file? Should I data log it?
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by z0sleeper View Post
    Haven't been able to look like it. It sounds exactly like DFCO because it enables anywhere above 1,500 rpm. You'll find the adjustments in the cutoff section.
    618/618 motor
    906/862 spray
    Apr 2012
    20
    This seems to only happen when car warms up, can I try enable 2500rpm and disable 1200?
    Aug 2010
    Roswell, N.M.
    1,956
    Yep you can try that. If it still does it, the problem is clutch fuel cutoff. P.S. I would not leave the rev limit at 7,400 rpm. That's too fast even for LS7 lifters. About 7,200 is max.
    618/618 motor
    906/862 spray
    Apr 2012
    20
    Quote Originally Posted by IDRIVEAG8GT View Post
    Thanks man,
    I posted up my data log drive from today. Didnt change the dfco yet. Let me know what you think.
    Any idea why my car dieseling when shut down.
    Aug 2010
    Roswell, N.M.
    1,956
    Thanks man,
    Lol yes I do. How to fix it, I still am not sure. Something about the TPS reopeninf to default before the car dies.
    Will look at log later.
    618/618 motor
    906/862 spray
    Apr 2012
    20
    I did a shut down log today tps goes from 18% to 28% on it own.
    Aug 2010
    Roswell, N.M.
    1,956
    Exactly and that is what causes the dieseling. I really don't know, nor does hardly anyone know how to fix it.
    618/618 motor
    906/862 spray
    Aug 2011
    Alaska
    566
    Is there a way to decrease DFCO rate? I'd like to reduce it a bit, if possible. I'm not a big fan of popping every time I lift the throttle. My AFR jumps to 21 when it engages. That seams a bit too aggressive to me.
    When arguing with an idiot, make sure he isn't doing the same thing....
    5BA8
    4,332
    Quote Originally Posted by Michael_D View Post
    Set your DFCO entry and exit timing to something like 15 or 18 degrees. That will remove almost all the popping.
    email=[email protected]
    Dec 2008
    on the Dyno
    1,824
    I have found most dieseling is caused by wrong injector data. I have a procharged c6z in the shop right now that had 85lb fast injectors which I don't personally have the data for. The car was extremely hard to start and when you shut it off it would keep running for a good 5 seconds. Put a set of stock injectors in it fired the car up nearly like stock and shut off like stock. So with that said getting the fuel shut off when the engine is supposed to shut off is key to keep it from dieseling. The gen4 stuff seems like they are more touchy on that than older gen3 stuff.
    I ordered some 80lb Siemens injectors for this car just because I know the data on them and the QC seems much better on them than the junk EV14 FAST injectors. I don't think the particular FAST injectors we had ever actually closed when pressure was on them. They seemed to leak down pretty bad.
    Located in Central Kentucky
    ShorTuning
    Aug 2011
    Alaska
    566
    Thanks Ed! I'll give that a try.
    Jun 2011
    Montreal, Canada
    758
    Quote Originally Posted by LSxpwrdZ View Post
    I agree. I know of a few cases of dieseling where changing the injectors (to ones with known good data) has solved the issue.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Sep 2008
    1,668
    ZR1 DFCO timing tables cure it...they're even higher. I put in the numbers from the ZR1 and I have literally no popping at all in DFCO.
    Whoever said his AFR is going to 21 and that's too agressive...that's just what your wideband maxes at...your AFR is going to just air when you're in DFCO. The injectors turn off. The popping noise is residual fuel blowing up in the pipes because there's not enough spark advance to light it off in the chambers...or it's crappy injectors not closing well...either way, with enough timing, it'll all happen in the chamber and you won't hear the popping.
    2023 Durango Hellcat
    5BA8
    4,332
    Quote Originally Posted by MikeOD View Post
    That's exactly right.
    Aug 2011
    Alaska
    566
    Ya, I understand what's happening. I just didn't know it was a complete shut off.
    I understand the DFCO entry tables, but the exit tables are confusing. Mine (stock tune settings) are all negative from 0 RPM to 3072, then 0's the rest of the way. -10, -10, -10, -8.5, -5.5, -3, -1.5
    DFCO entry was +10 across the entire RPM range. I moved these to +18 and there is less popping, but I still have some.
    For DFCO exit, do I want to move those numbers to +15 - or so??
    5BA8
    4,332
    Set the DFCO exit to +15 or so.
