had a limp code issue so tried Scanner it worked with limited pids.. After a few times though it will not connect anymore.. I can clear codes and check dtc though.. So thought I would try n see if pull tune file and no luck.. What am I missing here? worked with no issues then now nothing? my buddy beta scanner worked but showed -numbers on all pids which was really strange. this is my first diesel messing with and im using the 2.22 software.. it appears it has a dsp5 switch on it.. could this be why as well? help maybe?
