Hey everyone, I'm new to the forum just picked up HPT pro for my 2006 cobalt ss/na with the LE5. I have full bolt ons and currently have a trifecta tune I will soon get rid of. Anyways I have been logged said tune and am pretty sure it isn't good. I'll attach a log but I am seeing up to 5 degrees of knock retard at points and constant knock throughout each pull. Also the knock usually starts after the car leans out to about 13.5 AFR. The first log is without my AEM wideband and the second I finally got it hooked up. But on a good note I am seeing almost 20 lb/min, that's pretty good right?
Also I was wondering how I can log commanded AFR as the one I tried in the second log didn't work. Also is there a way to log the cam positions? Like intake and exhaust advance/retard? I thought I saw a couple logs with it but cannot figure it out.
I will start tuning once I can get the Trifecta flashed back to stock, so any info/ suggestions you have I'll gladly take! I've been reading alot of the VVT info but haven't found much good info on NA tuning. Also I need to learn how to MAF tune haha.
