Results 1 to 5 of 5
Thread: can´t get fuel cutoff higher HELP!!!
    Hi
    i must be missing something here
    i thought i had all tables covered in °getting the fuel cutoff in higher rpm but it doesn´t change
    i´m trying to get it to 6800
    but it still cutoffs around 6300 still in neutral when i rev it up
    1999 TA
    what am i missing here
    thanks
    Baezi
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    I don't see any reason for it. Download the tune from the car and make sure the changes took or try reflashing it if you haven't already.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    Are you doing a calibration only or a full write. Sometimes the full write gives it a clean slate and it picks up the changes.
    Quote Originally Posted by futuretech View Post
    tried both.....
    Baezi
    Jun 2007
    Finland, Europe
    550
    Does it work with lower values? 4000 rpm? 5000 rpm? 6000? 6250?
