Let's say that I upgrade or buy a new MPVI Std or Pro Interface.
- What kind of warranty comes with the unit?
- What is the turn-around on getting it repaired under warranty?
- What are the costs to repair it when it's out of warranty?
Bill
Bill
I asked this on LS1tech.com and Bill posted it here for me, anyone from HPT have an answer?
ttt
2007 CTS-V LS2
in the Help file under Introduction, Warranty.
Chris...
I count sheep in hex...
to answer the other questions
it depends what is wrong with it. ie. if you fried it by connecting incorrectly (such as EIO inputs/outputs) then you will be charged for a replacement. Other cases will be judged on their particular circumstance, turn around is also dependant on circumstance. eg. if you bent a connector or something accidently then the interface would likely be repaired.
Chris...
