Results 1 to 9 of 9
Thread: My tables are shortened?
    Apr 2005
    Sugar Land, TX
    1,198
    Wondering why my tables have the bottom portion of the values cut off?
    28,303
    likely because you have your DPI settings to something other than normal.
    Apr 2005
    Sugar Land, TX
    1,198
    Ran a search and saw where they talked about DPI setting but where are they?
    Tuner in Training C Del's Avatar
    Oct 2012
    44
    On Windows 7 (and probably Vista) computers, you can access DPI settings by searching "dpi" in the Start menu. On Windows XP, It should be in the Control Panel, likely under the Accessibility options. IIRC, 96 DPI is the standard format.
    Apr 2005
    Sugar Land, TX
    1,198
    Quote Originally Posted by C Del View Post
    I have Windows 7. Typed in dpi and tried all of the settings but found no 96 dpi.
    28,303
    try control panel-appearance and personalization-display
    Apr 2005
    Sugar Land, TX
    1,198
    That's it! Thanks Bill.
    Only problem now is my print is so small I can barely read it.
    Oct 2012
    44
    You could reduce the resolution you're using; of course this is all kind of silly since the real problem is that the programmer who wrote the table control made a bad assumption that he had control over the font in use (or didn't have time to really sure up the layout code). Being that this is all .NET, I would think it would be fairly simple to hook up some scaling, depending on how the control is written.
    Apr 2005
    Sugar Land, TX
    1,198
    Went custom and set my dpi on 135 and now all is fine. For some reason it was on 150. 96 is too small to read.
