http://www.dsxtuning.com
Just say no to bull s***.
Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
618/618 motor
906/862 spray
Caterpillar 50 Forklift- Duramax swap
Thanks for the help IDRIVEAG8GT! I'd like to talk to these GM calibration engineers... see what they were thinking!
EDIT: Are you talking about the "Warmup Transient Fuel/BASE GAIN" or you talking about the "Impact Factor/Gain"?
My Warmup Transient Fuel/Base Gain table is all 0'd out... so.. any suggestions what to add in there to get started?
ZL1 Wheels/Tires
Warmup Transient Fuel Base Gain. Just highlight the whole damn thing and that will take care of your issue. I've been testing it thoroughly today and it's working spectacularly.
Use what is in my tune under the transient tab, and I mean all of it, the changes with the EVAP factor, base gain, etc etc. Chances are that it may go way rich between shifts, in which case you should simply reduce the transient base gain by 10% at a time. Enjoy.
618/618 motor
906/862 spray
618/618 motor
906/862 spray
ZL1 Wheels/Tires
Update: I noticed something weird as hell on my G8. When I write a tune into it on its first start, I can go out, drive the car, go WOT and it'll do exactly as it should.
But as soon as I kill the car and restart it, it'll act fine until I go WOT. Then it's like the car completely forgets it has a transient fuel mode. With quick throttle transitions it has a noticeable dead spot where the IPW doesn't spike whenever I hit the gas. The rpm drops about 200 like the engine is dead for a bit, then the Pulsewidth spikes and it takes off.
It is the strangest thing I have ever seen.
618/618 motor
906/862 spray
Thats what I've been noticing myself...but it also showed a dip in throttle % and O2 m/v dropping all at the same time.
Hey Bill/Chris, are you guys reading through this? We might have a small problem that I think only you guys can fix.
Bueller bueller?
618/618 motor
906/862 spray
Well to start I would say that your transient settings are working (fixed my LEAN PE DELAY I was seeing) as i haven't seen a lean out.. and I do finally see an increase in pulse width when I stab the gas.. I never saw that before, and AFR's immediately shoot down to PE levels when I hit the gas which is great, but I haven't shifted fast and and hard like I did before... but before I never saw the increase in pulse width related to "pump shot" so I know your settings are a huge improvement, and I haven't seen really any negative side affects even during decel, so THANK YOU.
Now on to this long term cancellation of the transients your mentioning... so far I haven't had my file in the PCM longer than 1-2 drives since I'm dialing in WOT PE MAF tables... but I will definitely start looking at it.
This is interesting as I'm on a 2010 Camaro and your on a G8... just curios if the platform or the OS has something to do with it... either way we should know soon.
ZL1 Wheels/Tires
Consider this. My E38 equipped truck with 2.5 BAR enhancement is doing the SAME DAMN THING.
And a customers E38 equipped Z06 with a fairly large cam is doing it too! And it's not even 2.5 BAR. Wtf.
618/618 motor
906/862 spray
well that's not good at all. Can it be linked somehow to LTFT or STFT correction?
So your saying the initial pulse width spike is totally gone? Just asking so I know what to look for.
ZL1 Wheels/Tires
Stft's were around -4%. And no the Pulsewidth Spike isn't gone. It's..... Delayed!
Frame shows that the dead spot lasts for around two tenths of a second.
Basically you hit the gas, hear the suction noise as manifold vacuum goes away as the TB opens, but nothing happens. The RPM drops like you killed the ignition, AFR pegs the WB lean, then the Pulsewidth spikes out of nowhere and the engine takes off like nothing ever happened.
But like I said, only after you kill/restart the engine and hit WOT once.
It also does it regardless of RPM or current TPS.
A Write Entire doesn't cure it either.
618/618 motor
906/862 spray
618/618 motor
906/862 spray
93 Ranger. 5.3 D1X. 1069hp.
its doing exactly what you two are suffering from. i may drop back a beta and see if its a beta issue
Let me know. I'm very curious. See the reason I switched to SD on the new beta is because as soon as I wrote a new tune the car started doing this same exact thing in Pure MAF mode. It originally had me thinking my MAF was getting weak so I said screw it. Uploaded the 2.5BAR enhancement, spent a good 5 hours over the course of two weeks tuning it and bam! I now have the exact same issue without a MAF sensor.
Dont get me wrong, I love all the updates of the new OS., like the addition of a BE table and extended fan temp controls. It's all awesome. But, I would like to revert back as well, just to test myt but then I lose SD and the fact that I removed and sold my MAF sensor sucks. Whenever we get a few more hard facts on what is going on here let's email support and see if they can figure it out?
618/618 motor
906/862 spray
