Results 21 to 40 of 60
Thread: VE Table for 2Bar OS
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Couldn't we then just apply the lambda error to the Maf based dynamic air calculated GMVE? Then we'd have an corrected GMVE even with the maf being out of tune, or is there more to it than that? I like this method btw, it sure would've saved me a lot of time.
    Jun 2008
    NM
    52
    If I told you how to do it, you wouldn't learn anything!
    Things must have changed since I went to school.
    I am struggling with this very issue. If there is someone out there who can assist me in understanding how to do this properly and give me feedback while I learn how to do it, I will paypal you for your time.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,862
    I'm an engineer. I was always told to just figure it out.
    Read up on how GMVE is used to calculate a cylinder load. Change the equation around so that your calculator GMVE from cylinder load, MAP, and MAT. Now think about how cylinder load is related to injector flow rate, injector pulse width, and AFR.
    I could post the PIDs that I spent a good chunk of time writing out (PIDs that use lambda instead of AFR and compensate regardless of what the stoich is programmed as), but like I said, nobody learns when they are just given the end result. Plus, I just don't want to give out for free what I worked hard to get to.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by ZZMike View Post
    It's because Dave hasn't had his pickle tickled in awhile. :O
    Really though, MOST of us here are engineers, all with our dedicated specialties.
    I've gotten good enough at load testing now I can generate myself a perfectly good running VE table by hand in the matter of about an hour. Are there better tables? Probably, but my fuel trims and AFR stay in line no matter what so I don't really care. Lol.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    I gave a working 2 bar tune to the CamaroZ28 community (that I also spent a large amount of time realizing baro reset was causing all kinds of problems, getting Tunercats/LT1Edit to find the tables, and how to fix lean tip in with no tables).
    I just gave that away, posted the tune on the website and they made a sticky.
    For me, helping people makes me happy. There needs to me more of me in the world!
    ZL1 Wheels/Tires
  6. #26
    Mar 2008
    St. Louis, MO
    4,862
    I guess Coke should give out their formula so people can make their own soda.
    Gooooooooooooooooood luck.
  7. #27
    Aug 2010
    Roswell, N.M.
    1,956
    Nobody likes Coke.
    618/618 motor
    906/862 spray
  8. #28
    Apr 2007
    1,104
    Quote Originally Posted by IDRIVEAG8GT View Post
    Nobody likes Coke.
    i do dammit!
    93 Ranger. 5.3 D1X. 1069hp.
  9. #29
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Area47 View Post
    i do dammit!
    618/618 motor
    906/862 spray
  10. #30
    Quote Originally Posted by Michael_D View Post
    I'm going to have to ponder Dave's comments to figure out what he said.... Initail pondering has given me a headache.
    At any rate, I used the Bluecat tool to pull the data out of my tune file and built the VE table from those coefficients. After I had the table in the BC application, it was pretty simple to just copy/paste that data into the 2 bar VE table. I am NA, so I did not need to run MAP about 105, so I was able to increase resolution with the extra cells the 2 bar VE table had by interpolating between columns.
    After this rough' VE table was built, I used my wide band and VE / AFR error histo's to polish it up a bit.
    My VE table above 5000 rpm however is way off. I got a bit nervous trying to dial that area of the VE table in with PE disabled and all the SD multipliers set to 1.
    "After this rough' VE table was built, I used my wide band and VE / AFR error histo's to polish it up a bit."
    I have been trying to figure out the Bluecat copy, paste, edit, paste thing for a couple days now. I'm still unable to build or find the correct Histo. (RPM/MAP vs AFR err) in HP Scanner that coresponds with the VE table in the custom OS. I have the 2bar - 210 kpa map (horizontal) but not the 6,800 rpm (vertical) The table I have reads to 8,000 rpm's vertical. I try to build one but keep getting odd numbers displayed. Ex: 400.600.801. 1000.
    I don't think I am asking anyone to give up the farm, just a little help.
    2011 Camaro, 430cu Lsx, Mast Heads, Ported TVS 2300, ID 1300's, E85-Flex, Squash Fuel System, 250 Direct Port Nitrous, LPE Overdrive rear 10/14 Rib, Overdrive, 2.8" Upper, NW 102, 2" ARH, PATC built A6, Circle D Conv. etc. BMR 15" Wheel Conversion w/29/10.5W's/15 Hoosiers
    2007 H2 SUT, 427 LSX, T76 BB@16lbs 225 Trickflows, Vic JR Intake, Lt's, Dual return fuel sys, Comp 236-232-115, 4L80e, 3000 Vigilante, etc.
  11. #31
    Sep 2011
    Jax, Fl
    216
    GMVE = AFR*Fuelmass*MAT/MAP?
    2006 Holden Monaro I Phantom Black Metallic I Red I One of 416
    L92/L76 I Streetsweeper HTR I SLP LT I LoudMouth 2
    JHP V2 I Powdercoated Black 18s I Kyne Splitter
    2001 GTP I Stock DD
  12. #32
    Jun 2008
    Charleston, SC
    969
    i just added a maf screen, ditched the 50% scale bullshit tune, and went with the double stioch method with a maf tune. had car dialed in with 3 street tunes, then three wot passes.
    back on 93 octane until summer time rolls around.
    I read the thread, and I understand where it is giong, but I honestly dont have the time to figure it out. I'm a perfectionist and I can see my self obsessing about it for weeks until it was perfect.
    -Carl
  13. #33
    Mar 2008
    St. Louis, MO
    4,862
    Quote Originally Posted by Kyne View Post
    Now calculate the fuel mass based on loggable parameters.
  14. #34
    Sep 2011
    Jax, Fl
    216
    I don't want to give it all away either. IPW*IFR? But how do you make it so it works with Lambda and not AFR? AFR in the equation = lambda*stoich value?
    2001 GTP I Stock DD
  15. #35
    Jun 2008
    Charleston, SC
    969
    commanded eq = lambda
  16. #36
    Sep 2011
    Jax, Fl
    216
    Quote Originally Posted by carlrx7 View Post
    Is this in reference to my post? commanded eq = 1/lambda
    2001 GTP I Stock DD
  17. #37
    Jun 2008
    NM
    52
    For those who have PMed and assisted me in gaining an understanding, thanks.
  18. #38
    Oct 2011
    Gainesville, VA
    301
    http://forum.efilive.com/showthread....-decomposition
    Looks like most the info is right there, but just like RHS said how accurate is that? Add in all the different injectors out there without any reliable data and....
  19. #39
    Mar 2008
    St. Louis, MO
    4,862
    I will say this. I've used the back calculation with IDs, stock injectors, and mystery injectors.
    It works great with IDs and stock stuff. It will literally get you to within 2%. Other stuff...
    Not so well. It will still rough it in though.
  20. #40
    Oct 2011
    Gainesville, VA
    301
    It just seems like a lot of variables each with their own degree of inaccuracies, which depending on your injectors, wideband, overlap etc could add up to a large error when all calculated together. The Same can be said of the MAF too i guess for different reasons. I'll give it a shot tonight though just to see what i get.(car is already pretty spot on) I'll sample both and maybe try averaging the two, anyway thanks for the idea.
