Results 1 to 16 of 16
Thread: Rev limit hit before Desired Limit
    Guys I just got off the dyno tuning a car . The car made great power everything seemed good until we tried to rev the car a bit more. I had been reving the car to 6400 without an issue. Now that I am trying to rev it to about 6800 the car seems to be hitting the rev limit at 6450 or so. Can you guys check the tune and let me know if you see anything that could be causing it.
    The only things i see is that the MAF gets maxed out. I know there is a patch for it but I believe the patch is already applied. Unfortunately I do not have a log as my computer died while trying to capture the log. Also the map is maxing out but I doubt that has anything to do with it. But I do see the Maf maxing out on the car
    This is an LS2 motor original car with a crate lsx motor. I know he is using some type of lingerfilter signal changer for the crank to be able to run the car with that motor
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Is the car boosted? On some cars if the MAF maxxed out they roll back over to zero HZ. It'll feel like a rev limiter, but it's not. Just a severe lean spike.
    If not, the tune usually has three different sections for controlling the rev limiter such as Extreme Cutoff, cutoff versus RPM, and startup seconds versus RPM. You'll find your problem in one of those three tables, and yes they're all located in the same section.
    Can't view your tune right now or else I'd point it out to you.
    -Rob.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Jan 2009
    Spokane, WA
    480
    Also make sure you aren't maxed out duy cycle wise...
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    Can't open the file because I'm on my phone, but I would bet its the startup limiter.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Feb 2008
    Sikeston, MO
    173
    Quote Originally Posted by dsmlights View Post
    I don't see any obvious causes. You really need a log file for others to view, preferably with a good wideband setup. It's not the startup rev limiter or any other obvious ones I can see, so I would guess it's something going on, maybe a lean spike as IDRIVEAG8GT said.
    Also, how are you deciding the RPM it's rev-limiting at. The tach often doesn't keep up with the engine. If the scan says 6450 that's different, but many times I see a car someone thinks it say shifting at 6500 and it's hitting 7K.
    28,319
    I don't exactly know where to start.
    But I'll start here.
    Your VE table is set to 0.
    You are running a 2 bar speed density custom operating system but still have maf enabled
    Boost VE is set to 0
    Start by setting up the tune for 2 bar speed density such as its set up for, the move on to issues from there, not the other way around.
    Bill although I am running a SD tune i should still be able to do a maf only tune if I wanted right ?
    Aug 2010
    Roswell, N.M.
    1,956
    ^ Bill was asking you why you upgraded since there wasn't much point in doing so.
    618/618 motor
    906/862 spray
    28,319
    Not necessarily.
    Quote Originally Posted by IDRIVEAG8GT View Post
    The car is boosting about 16 psi so the 2bar map was maxing out. I decided to go with the MAF. Also it was just easier to dial in. The car came already upgraded with the 2Bar
    28,319
    Pretty sure the E40 supports up to a 2.5 bar sensor so its not a sensor limitation as 2.5 bar should cover 16psi without issue.
    Aug 2010
    Roswell, N.M.
    1,956
    Bill, on an E40 can you run an LS9 MAP? (max 312 kPa)
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,863
    No. LS9 MAP has a negative offset value, and a linear value greater than 256kPa, neither of which the E40 will accept.
    Jul 2012
    Italy
    219
    so what is the right MAP to use for E40 in this case?
    Mar 2008
    St. Louis, MO
    4,863
    I build one that fits the range that the E40 is capable of.
    Nov 2012
    41
    I had the same issue on the std OS for some weird reason. Tripe checked all the values. Could it be that using fuel cutoff over spark cutoff could cause this?
